Crescendo BC2000D to power dual 1ohm
G-Rad
was going to say. "that doesn't kmake sense" I'll just do a 2 ohm load.
BASS MEKANIK RECORDS
"Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold!
2007 Ford Focus
(NOTE: My cousin's build I helped him with)
Pioneer H/U
(4) Absolute Dome Tweeters on A & C pillars
Scosche HD683A's in front doors
Fosgate R168x2's in rear doors
SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz
Audiopipe APCL-1800.1D
Q-Mat
Audio Technix 0 Gauge
119aH/850CCA Marine Deep Cycle batteries
YouTube Channel: http://www.youtube.com/DWRhythm
the 3kwps (amazing amps) were warrantied to .5, they did 4k (13.8v) for about 500 or 550. The new BASSCLEF series is only warrantied down to 1 ohm. So either recone the bitch, or save up for a 3500 and still only get about 1800 rms.
like HT said, bad planning. :shrug:
May do the D2 recone idea. I was originally planning on the sub being a D2, which is what I went with. Found out lastnight that it was a D1, which changed up everything. That's why I'm in the spot i'm in. But yeah, it does fall into the catergory of bad planning; moreso premature planning.
2007 Ford Focus
Pioneer H/U
Q-Mat
I would do it, but I'm not saying you should haha
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
I ran a [email protected] daily on stock 105 amp alt and a deka battery up front and big 3 done. Voltage sucked so I never turned it up much to make it drop below 13v. I would suggest a huge batt up front and huge batt in back, along with a 200+ amp alternator. Since you arent driving the car daily I would forget about an alt and just buy an xs power charger and keep it hooked up to that.
haha, right! I know I probably shouldn't now, reading up on it.
2007 Ford Focus
Pioneer H/U
Q-Mat
if you havent bought the amp yet you might want to try saving up and finding a amp that does its power at 2ohm such as alpines mrp-2000
  • Who's Online   0 Members, 0 Anonymous, 686 Guests (See full list)
