The "1500" watts amplifier CHALLENGE!!!
fecupe2001
Not gonna post clamp results from the t-1500.1bd then if you don´t want to, i guess getting the same power and score from the cadence amplifier is not accurated either?? don´t know what else i have to do lol
I wanted clamp results from the t-1500 :(
Still want them?? :drinks:
Guest grim83
post up what you got hoe
I just think people underestimate the amount of testing you actually do. And fuck yes, I would love the results! Please!
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
on a brand that he doesn´t like
brands i dont like? I have ran 3 different Maxxsonics amps. I never said I dont like them. And if I was in a pinch, I would run an ap1500 or 3k. I never said I dont like those either. I simply asked which clamp method you use, because there is a difference between peak hold readings and true rms readings. Peak hold readings typically show about a 20% spike more or less. Your tests were rendering 15-20% readings over rated, so I simply asked what method you used because your data pointed to peak hold readings. I used true rms readings when clamping Maxxsonics and AP products in the past, and my results were different. Mike from Maxxsonics even stated that Brutus amps quickly lose output after any voltage drop. The number for the BRZ line was roughly 18% per 1v dropped. I know you arent quite dropping 1 full volt, but there should still be some power diminshment. If you are using peak readings, that is fine, but viewers should be aware of that. That is all
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
Don´t need to post pictures again from the Rockford fosgate´s since i already did it a few posts ago.
Specs:
Power Specifications - Subwoofer Channel
RMS Power @ 4 ohms 500 watts x 1 channel
RMS Power @ 2 ohms 1000 watts x 1 channel
RMS Power @ 1 ohm 1500 watts x 1 channel
Peak Power Output N/A
Amplifier Specifications
Amplifier Class BD
Number of Channels 1 - Mono
Total Peak Power Output N/A
Total RMS Power Output 1500 watts
Maximum Input Gauge Size 1/0 AWG
Minimum Impedance Unbridged 1 ohms
Minimum Impedance Bridged N/A
THD at Rated RMS Power 0.8%
Speaker Level Inputs No
Preamp Outputs 2 pairs
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 35 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 24 dB
Bass/Gain Remote Optional (Accessory required and sold separately)
Fan Cooled N/A
Fuse Rating 150A
CEA-2006 Compliant Yes
Birth sheet on this little babt said 1961 watts @ 1 ohm, i know it´s not something to trust so much but still it´s a good reference point.
Clamp results:
46.9 Volts
44.3 Amps
46.9 x 44.3 = 2078 Watts RMS
46.9 / 44.3 = 1.06 ohms
Voltage drop : 13.9v
Termlab score, sealed on the dash @ 41 hz
I got 110 extra watts from the birth sheet, guess my test isn´t that bad at all :peepwall:
Anyways, i kind of felt heartbroken, i really thought the RF could be close to the m2a, but still, 2078 watts from such a tiny amplifier it´s pretty badass, stayed very cool on all the burps, played BEAUTIFUL on music, i have to say it sounds better than both of the DD amplifiers wich is great IMO, it´s a great choice since it´s powerful, small and from an awesome company like Fosgate :)
guess fosgate tests their amps wrong too!@#!#
lol, nice results as expected from the rockford.
any updates on if you can get your hands on a hfi hifonics?
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Specs:
Amplifier Class BD
Subsonic Filter N/A
Bass Boost 24 dB
Fan Cooled N/A
Fuse Rating 150A
Clamp results:
46.9 Volts
44.3 Amps
Sweet, that's my bass amp right now. Love to hear it sounds nice compared to the m2a. :woot:
Hey sheena, still looking for it mate, but can´t seem to find one for this test, there´s a chance that i might get an hfi2500D wich would be cool, but still waiting for some confirmation :)
Yeah, results were very nice, the best amplifier on music between the 7 that i tried, period!!!
Specs:
Amplifier Class BD
Subsonic Filter N/A
Bass Boost 24 dB
Fan Cooled N/A
Fuse Rating 150A
Clamp results:
46.9 Volts
44.3 Amps
Sounds VERY nice, better than the m2a IMO, great SQ coming from this little baby :)
hey i don't want you to think that i was bashing you at all just stating what i saw i appreciate you doing this but i also thought it was a lil suspecious that all the amps tested over rated and i see what you are doing now. wasn't trying to say you testing was wrong man just that efficency wasn't factored in. appreciate you tests man and thx for doing it and i even loved you spl topic :good: sorry if i repeated my self a lil drunk :drink40:
Javier, what AC clamp meter were you using? Sorry if I missed this... btw, fosgate didn't surprise me.. it was expected <_< . great job nonetheless!
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
