DC Sound Lab
Excuse the poor quality video. I did it more so you can hear what it sounds like than to hear what is going on.
It makes this sound, moves less for a fraction of a second, then goes back to playing. It does it only at certain notes (and it's not bottoming out)
Ideas? It's a level 5 15 w/ reinforced surround, 2 extra medium spiders
http://www.youtube.com/watch?v=7s67rAXXYgs
Edited by SnowDrifter
i have seen this happen when the sub is going below box tunning and theres no subsonic control set on the amp,does it happen on all music, is your box ported, and what is it tuned to , also do you have a subsonic filter? could posibly playing a frequency a good bit below box tuning.
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
Almost sounds like tinsels are shorting.. check them and or speaker connections..mite be amp or rcas also
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Ported box tuned to 30hz, the noise making note is at 32 hz, and subsonic is set at 25hz if that's any help
my sub did that once. sold it to a girl who beat the living shit out of it (including blowing the amp she had for it) and now it plays better than ever
soooo... :shrug:
sorry i wasn't more helpful
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I'd like some help on this too. Not tryin to thread jack though. But i currently have 2 kicker L7 15's and one of mine does that too. And they're sealed
Too much air space.
sounds like you possibly got coil rock...make sure your triple joint (where the former, spiders and cone meet) is all intact, make sure your spiders didnt come off the landing...
honestly i think its the spiders came of the landing causing them to slap the landing when playing and they need to be re-glued down. pull the sub out of the box and push the cone up from the bottom and see if anything looks out of place...sounds like an easy fix to me.
NoFearX18 said:
trainman0978 said:
