XS Power
If you replaced your stock ground, make sure it didn't have a plastic piece that was around the ground cable. Some vehicles have sensors in place around the cables and if that sensor is not there, then it is basically breaking a protection circuit built into the vehicles stock electrical system. This can mess up your electrical because the vehicle isn't able to get a full electrical reading.
Also check and see what the voltage is coming off of the alternator under the hood and at the battery in the back.
That's a bunch of bill having to by a special gam charger just so you can charge it up before dropping it in. I don't have to charge up a fucking autozone battery before I install it.
you have no idea what u are talking about please stop posting
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
It was just a piece of 4 gauge wire. No sensors around it.
Since I don't have a agm charger, can I charge it with regular charger? Also, how long will it take to fully charge it?
Voltage in the back is at 14 volts.
no use a amg charger, i have this sear charger works great for under 100bucks
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Are you still running the Kinetik too? If you are mixing batteries, you should run a battery isolator. This will prevent your batteries from using each other to maintain a charge, which may be happening. If the battery you have wasn't charged and you add it to the mi, then it will suck juice from the other battery and alt, etc etc. Or something along those lines...if I'm explaining it right. :peepwall:
10501650_10203332501847103_1859383749711
Blown
Whats a d3100? You need a yellow top or two and a cap. :lol:
See if you can find someone with an agm charger to charge it.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
thats only when using different types of batts, both xs and kinetik are deepcycle AGM..
if it was a wetcell or drycell, it would be a big difference
no need to do that with this batt
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Running just a D3100.
Whats a d3100? You need a yellow top or two and a cap. :lol: See if you can find someone with an agm charger to charge it.
:rofl:
  • Who's Online   0 Members, 0 Anonymous, 2425 Guests (See full list)
