hello everyone, im getting very frustrated with my engine noise. It is a very basic set up. Here is what im dealing with
2010 f-150
pioneer x910bt
mb quart componets in front doors
mb quart 5x7 in rear doors
mb quart onx80.4 4 channel
4 gauge power wire along passenger size, 100 amp fuse.
4 gauge ground grounded to the back cab metel behind rear seats
remote on passenger side
scoshe rcas brand new from walmart along the drivers side, the rcas never come within 12" of power wire.
here is what i have tried so far
turned gains way down
different ground locations
4 channel ground loop isolator
pionner ground rca tricks
the noise is very faint when you turn the volume all the way down. It never increase in volume, but it does change with engine rpms. when you turn the volume up you can no longer hear the noise. however it is a pain in the ass using the bluetooth phone or gps when the music is off. This is a almost brand new truck and i do not what ANY nosie in the system. Any suggestions?
I once changed an alternator and got rid of the noise I guess the regulatory went bad and was causing but that's one fix I've had. The other was relocated my bass knob control on my pac lc-1
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
These rpm threads always are associated with pioneer decks. I'm not saying whether it is you deck or wiring, but just seems like a noticeable trend.
Make sure your power and rca are seperated also your remote wire. The power could interfere with the signal
power wire goes down passenger size, rcas down driver side
i don't have any subs or bass knob, the truck only has 9k miles on it so im doubting the alternator
how is the speaker wire ran?
speaker wires go down the driver size with the rca and taps into factory wire behind radio
Where did you ground the deck at? If you disconnect the rca's is the noise still there?
deck is ground to the black wire that comes from the pac interface, if i disconnect the rca the noise goes away, also before i added the amp there was zero noise
maybe better RCAs?
Vehicle: 2008 Mustang V6
Exterior: Blacked Out Taillights, Turn Signals, Side Markers-Black 18x8 Enkei ls5-6000k HID's
Interior: Blue LED Strips with Module for Music-Hardwired Beltronics RX65 with Blue LED and remote button
Sub: 2 10 inch custom subs
Amp: Hifonics BRz 2600
Wire: Knu 0 gauge
Headunit: Kenwood kiv-bt901
Damplifier: Fatmat Rattletrap
Electrical: Stock Alt/Stock Battery/Big 3
  • Who's Online   0 Members, 0 Anonymous, 594 Guests (See full list)
