Whats this new JUICEBOX battery company?
Looks like $269
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
the only Juicebox I'd slap in my car is the one by Gorilla Zoe 8)
1 x Wolfram W-4500.1
2 x XS Power D5100's
250A Singer Alternator
2.67 Cubes @ 29hz
This but Decaf version.
Evo X build log
how much are juice box batteries tho? xs power do seem to be top dog but they also seem to be most expensive and for some of us price is a big factor when your on a budget you cant always afford the best... if i had the money i would drive a lambo instead i have Mitsubishi evo that will give the lambo a run for its money at a fraction of the cost.
Your talking about a test that was done with two completely different load test machines starting voltage was not the same. When you start a drag race its a straight line across and go when the flags are dropped. Was the Xs battery able to climb back up to the initial 17.15 or so that it started at? Last number I seen was in the 16's never was did juicebox make a claim to be better than anyone that I seen. Mike singer did a test that proved the juicebox to be right in par with all the big name companies for a lot less. Xs makes great product and that was never in question the real test was to see how well the juicebox held up and under the test that was done only the juicebox dropped 1.55 volts and the Xs dropped 1.6 volts so in that test alone I would say that juicebox brand batteries held its own. Imo. Juicebox ftmfw.
doesnt matter what type of load tester you use ... 100A is 100A and the test was done at each batteries resting voltage, each battery has a different resting voltage is xs is higher than its their advantage. you wanted to use drag racing as an example so here is mine ... you get two cars one with 500hp one with 550 .... do you lower that car with 550 to 500 so its the same ... no his has 550 so its his advantage. and the ending voltage after the load test is much more important than how many volts it dropped the xs power batt has .39 more volts than the 2 juicebox batts at the end to me that was not in par.
