I don't like the idea of drilling a bunch of holes in my wall to run wire through and plan on using some bolts and ring terminals and I was curious if there is any impedance change using that method? Would you guys recommend stainless, brass, etc?
Edited by TheScottishBear
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
I don't believe that there is any change in the Independence, Just wire each + and - to its own bolt from each sub. Then you can always change by using small leads on the outside of the box to change for like going to a comp and driving daily. Most that I have seen on the forum use brass bolts. hope that helps
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
ive used both stainless and brass bolts before... i tend to like brass little more less resistance.. but brass costs twice the price of a standard bolt
i prefer to drill them holes and run wire out..that way from sub to amp there is no break in the wire.. more flow
Edited by getlocivic
direct connect is where its at. As long as you seal the hole up good. Which isnt hard if you use the right sized bit for your wire its going to give you one less point of failure.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I used zinc plated bolts.. and copper ring terminals..
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
I 2nd this. Best thing to do is right here.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
The resistance on a bolt is something like. 01 or something. If you like to change loads its best to do bolts. Since I don't I use a direct connect
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
/thread !!
That´s the best answer you are gonna get, i always change loads and that´s the only reason i use bolts :)
