Hey guys, im sorry if this is in the wrong category, if it is could I have a mod move it to the correct place, thanks!
I have a 2004 Silverado show truck, it has a 4.3l v6, with A/C. It has a 300 amp boss alternator. Whenever the truck is cold, I start the truck and it starts squeaking. Sometimes when I pull out of the driveway it will squeak alllll the way down my street. I called an alt shop and gave him the symtoms, and he gave me something to try. He said start the truck when its cold, let it squeak for like 5 seconds, then shut it off, and run under the hood and very quickly just touch the alts pulley. It was burning hot, and he said thats a sign the belt is physically squeaking on the pulley, because if it was free spinning it wouldnt heat up that fast since the friction of the belt slipping would make the pulley that hot in no time.
I called boss alts, they were no help at all. he didnt have any way to fix it, he said find a local alt shop (which i did) and ask them to fix it. he said if they couldnt fix it to just send it back. he said he had never gotten a phone call with this problem and hes sold hellla alts for a long time.
Before these phone calls, I replaced the belt, tensioner, and idler pulley, and was advised to NOT use belt dressing.
What should I do next? i was recommended to try a different belt called a gatorback by good year, what do you guys think? Im going to post this in my project thread too so more ppl see this thread
Please somebody help!!
Gary 'Numatik' Eberle
West Sacramento, California
Vehicle build log (1) 'Aayla' Numatik's one and only, bodydropped pasted the doors Chevy S-20 Ext-Ext cab. This project ended after a horrible horrible motorcycle accident. There are so many mods it would fill an entire page in my sig. Check it out if you have A LOT of time to kill. http://www.stevemeadedesigns.com/board/topic/39785-numatiks-doored-s-20-bodydropped-on-doors-ext-ext-cab-10-subs-full-frame-build/?hl=%20numatik#39;s
Vehicle build log (2) 'Snow White' Daily/showstopper 2004 Chevy Silverado
Lays on 22s soon for 26s to run a beefy tire on 4s (4) 5gal tanks, (3)AZOB2 pumps, Slam digital stealth two speed valves with 16 solenoids, Slam SS bags all around, ART upper and lower arms, KP Components 6-link, KP Components watts link, Panther juice 6 22s, Spikes EVERYWHERE. 3,600WRMS total, (5) Kicker amps, (2) L7 15s under raised back seats, 15" screen molded to dash, 36 speakers total all Mb Quartz and Fosgate. Fiberglass console with removable face plates and arm rests, flushed speakers, lots of toggle switches, Playstation 2, rear view camera, Suede and leather seats, suede headliner, Dakota Digital air gauges, voltage gauges, and current draw gauges. (2) XS Power 4800 batteries, Whole truck is flat black and white and the
ENTIRE truck is fully pin striped by TJ Pagano here in Sacramento.
http://www.stevemeadedesigns.com/board/topic/123328-numatiks-bagged-2004-silverado/
"What doesn't kill you makes you stronger. I am proof" - Numatik
i think it means bearing are going out. if the alt is old or have cheap bearings.
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
this
also does it have a belt tensioner thats adjustable or a spring loaded tensioner? i was asking because if you tighten your belt too much you can wear out the bearings in the alt quick causing that fimiliar sqeak.
good luck :)
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Can you move the alternators pulley, or atleast turn it over see if it spins by hand?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Typically a hot pulley usually means that you have belt slip. It doesnt always indicate a bad bearing. You could buy a listening probe and put it on each of the pulley's to listen for any grinding or squeaking noises as that will help you pinpoint what pulley may be the culprit.
Here is what i would try:
Remove the belt from the engine. With the belt off all the pulley's take your hand and put it in the 12 and 6 o'clock positions and attempt to rock the pulley up and down. Then take your hands and put them in the 3 and 9 o'clock positions and attempt to rock the pulley left and right. If the pulley rocks then your bearing for that pulley is on its way out.
I also had the occasional belt squeal on my envoy when it is somewhat warm out toward the end of this fall. I just sprayed some lithium grease to the back side of the pulley's as they were not wobbling at all and it fixed it for the most part. Sometimes i get the occasional squeak but its not as loud or as long as i had before i sprayed them.
I would also highly recommend you get brake parts cleaner and a clean rag/towel and clean all your pulley's off. Spray the brake part cleaner on the rag/towel then wipe the part of the pulley's that the belt rides onto. Make sure you do this until they have no oils left on them or when you wipe the pulley you cannot see any dirt collecting on the rag. I did this to all my pulley's and my belt without any problems. But to be safe i cleaned the pulley's off and installed a brand new belt from advance auto on my truck and its been fine, i have had no belt slip.
Hope this helps!!
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
this
good luck :)
I has a spring tensioner, and I replaced it 3 weeks ago. The alt is old, its been in since like 06.
Hope this helps!!
THAT I think is the answer, I did not try that till just now! alt spins freely, BUT if you grab it just as kiackassaudio sad it DOES have a little bit of play. I think its the bearings!!!! I'll take it to the local alt shop the next day there open (hopefully 2marro but they may be out for the holidays). Are alt bearings pretty universal, or am i going to need to get them from Boss alts?
In the meantime Im gonna clean the pulleys the best I can with brakeclean. Problem is with a towell I cant get get into the grooves, I think im gonna need to take a wirebrush to them. After cleaning and drying the best I can do I let the truck sit for a few hours with the hood up to try and evaporate everything completely dry?
I called the alt shop and explained what i read on here, he still says its not the bearings because the sound wouldnt go away then come back when its cold. Next week he said to bring the alt in and just put it on the test bench and see if we can get it to squeak. If we cant get it to its possible to eliminate that, but I dont have a listening probe, and im not sure where else to look.
I read earlier on a diff thread about people replacing parts of the ac that could be the squeak as well... is there anything else I should try in the meantime before I take the alt in?
If the alternator's pulley was really hot when you ran the truck for only 5 seconds then yeah it's definitely belt slip.. Try to make the belt slip by just pulling on it, if you can make it move then your tensioner is bad. Otherwise it's probably bad bearings in the alt, try to replicate what the belt is doing.. On one of those "cold mornings" pull the belt off the alt and see if it will spin, then put pressure like the belt would and see if it spins.
The tensioner, idler pulley, and belt have all been replaced recently. I will try that 2marro when the truck is cold, so just pull the belt and spin it with my hand? If the belt is slipping what other component do you think is likely to have something to do with the slippage? I dont know why it wont grab the alt without slipping, but after a minuted or a few, the alt does keep the batteries charged no problem at all
  • 3 weeks later...
I got the alt back from the shop today, he replaced the brushes, the tolerance ring around the hearing (which was cracked) and new bearings. The speak is GONE! Well that one is..... That big squeak that I wanted to fix is long gone, and now the ac is just starting to make a really low squeak, not that loud at all tho. 2marro im picking up a new ac clutch bearing and im gonna swap that out before this thing is squeaking like crazy how it was. But I am very happy that problem was finally fixed, it was driving me CRAZY. So fucking annoying!!
