99fullsizechevy Posted December 26, 2011 Report Share Posted December 26, 2011 4ohm dvc would be 2 ohm... Laying frame soon.. System has to wait Link to comment Share on other sites More sharing options...
TeamHT Posted December 26, 2011 Report Share Posted December 26, 2011 Well, if your front speakers are not working as well, then the issue shouldn't be your subwoofer amp. Unless your front speakers are hooked up the same amp... Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
TheNewbie Posted December 26, 2011 Author Report Share Posted December 26, 2011 I put another speaker onto the amp, it's not working. So i would guess it's my amp but isnt' there a way i can double check that? The Front and back speakers are running off the HU Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes. Link to comment Share on other sites More sharing options...
STEvil Posted December 27, 2011 Report Share Posted December 27, 2011 .... I vote the RCA's are toast unless your speakers are on the HU, then its probably the HU. If everything is cutting out: its not the amp. If only the sub is cutting out: its the amp (or a connection to it). MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
mattc3366 Posted December 30, 2011 Report Share Posted December 30, 2011 If I remember correctly a dual 4 wires to 2 ohms and im pretty sure that amp is 1 ohm stable it just puts more out at 2 than 1 subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch Link to comment Share on other sites More sharing options...
TeamHT Posted December 30, 2011 Report Share Posted December 30, 2011 Just stop. Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
OrionStang Posted December 30, 2011 Report Share Posted December 30, 2011 If I remember correctly a dual 4 wires to 2 ohms and im pretty sure that amp is 1 ohm stable it just puts more out at 2 than 1 SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
BobbyG2 Posted December 31, 2011 Report Share Posted December 31, 2011 Noone suggested checking the remote wire? My amp was doing this too, replaced the remote wire, and it started working fine again. *New vehicle and system coming soon.* Link to comment Share on other sites More sharing options...
Cosner90 Posted January 4, 2012 Report Share Posted January 4, 2012 ground Link to comment Share on other sites More sharing options...
TheNewbie Posted January 14, 2012 Author Report Share Posted January 14, 2012 Was the outputs on the amp, there donezo so says the car audio shop. Thanks for everyones help. I guess i just figured that wasn't it being that i didn't see a visable short or anything wrong inside the amp. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes. Link to comment Share on other sites More sharing options...
