Thats right Gents! The Rex is getting a beefed up b18a and a ls 5 speed tranny.
Engine is bored .50 mm with a ton of extras inside. Making around 200hp. I'll be picking it up tomorrow and will get build pics up asap!
Along with the engine swap I will be doing the suspension as well, upper control arm and camber kit for front, lower control arm and camber kit in the rear with 0-4in adjustable springs. I'm gonna bring the stance down just a tad :)
155 dbs and 200hp sweet. :clapping:
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Thanks!!
Will absolutely right no more getting passed by rv's lmao!! As far as the turbo goes maybe down the road( summer time ). I wanna see what this engine does first lol
Here are some stuff I know about the motor.
Block= bored .50mm oversize, shaved deck height .020mm
Crankshaft= LS Crank micropolished + magnafluxed for cracks.
Rods= Manley Sportsmaster.
Forged from aircraft quality 4340 material
Entire beam and cap are profiled to remove stress
risers and render the lightest possible rod
Shot peened after machining to Mil specs and 100%
individually magnafluxed
Cap fasteners are 7/16" ARP 8740 cap screws
Premium Ampco pin bushings
horsepower range for these rods is 800 H.P.
Pistons=Manley Platinum Series
2618 high strength material; lightweight design
Premium Chrome Moly pin included
Perfect ring groove to skirt squareness
Pressure balance groove
Premium Steel top ring sets and Round Wire locks included
Recommended piston clearance .0040" measured 1.100" from the bottom of the oil ring
Oil pump = OE Factory Acura new pump
All bearings= Cleavite
All seals = Comtect or OE factory
Cyl Head= all guides are new
All Valve are new Chrome valves
Timing belt new OE
Waterpump New OE
Camshafts= Stock
Cam Gears = Crower adjustable gears
Why not just swap in a LSX motor?
I'd hit that so fucking hard whoever pulled me out would be King of England.
Lol... looks like we were on the same page. Car-B-Ques suck.
ya, tires and paint burning make the marshmallows taste funny.
I got this motor which only has 5k miles built as it is now with ls 5 speed trans, ecu and axles for only 1k! This thing is stronger than a b18C GSR Type R which sells for 3500+ on average. It was a deal of a lifetime and fairly local being in Sacremento.
