Suggest an Amp for me please!!
USAFBordeaux
what about a 2ohm amp that's puts out 2000w?
you might be able to support a rockford 1501bd, 1600w RMS from 1-2ohms regulated, i ran both of mine at 1 ohm, never had a problem, you can find them as low as $150 on ebay, but i dont see any listed at the moment. You might want to check your local craigslist for some deals. There really isnt a reliable amp for under $300 that does decent power that isnt a few years old.
Edit: before someone tells me off, saying that the audiopipe 3000 is a great 1 ohm stable amp, it will play at 1 ohm for a while, but its not designed for it, and alot of them have caught fire because of it. It might do 1100w RMS at 2 ohms if you dont have any clipping.
Edited by SkylarDunn
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
don't forget amps are less efficient at lower ohms so it will hunger for power/amperage so that 120 amps seems like a snack
.5 ohms > 2 ohms
more amps > less amps
Edited by deathcards
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
the 3000d is a 2 channel amp, hook each sub up to 1 channel, run the channel at 1 ohm. Nuff said. or a crescendo 2k run it at .5 ohm. draw even more current.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
If you only have $300 to spend, keep saving, you wont get anything worth a damn for that price. Save up enough for an alt, put that in, then save up $500 for a crescendo 3500 (i dont remember what they cost off hand).
why crescendo?
Because they're built well, priced well, and it uses the same board as the sundown 3500. If i was going to buy an amp, i'd buy one thats not going to blow its mosfets in a year (the audiopipe 3000 comes to mind, and its not even actually 1 ohm stable either)
It is...
You can only wire it to 2ohms due to it being 2 AP1500's strapped in one case. Run at 2ohms, call it a good damn day.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
  • Who's Online   1 Member, 0 Anonymous, 2040 Guests (See full list)
