DC Sound Lab
So I'm really trying to do it big this year. I allready have 2 DC Audio Level 5 18's with D2 coils. I currently have a Stetsom 14K2d modded 18volt 2 OHM model and am running everything at 2 ohm on the 2 subs. Everything is awesome right now. So i thought i would step htings up a notch and bought another Stetsom 14K2d modded 18 volt 2OHM model with intentions of running 1 amp per sub. SO long story short ill have to wire the subs down to 1 OHM per subs on each 2 OHM version amp. Is this going to be a problem with the modded amps. I got some $$ in this setup and just want to make sure the amps can handle everything @ 1 OHM even though they are 2 OHM models. I dont have the room to buy 2 more Level 5 18's D2's and stuff them in the extended cab of my truck. Im looking to talk to some people that have done some serious testing on these amps and has worked with high end equip for a while.
1999 Ford F-150
1 Optima Yellow Top
5 XS Power D3100's
2 Stetsom 14K2D 18V Modded 2OHM Models
2 DC Audio Level 5 18's D2's <--For Sale!!!
Boston Acoustics GT-2200
2 sets of Boston Acoustics SR60'S
Knukonceptz 0 gauge
Soon Singer HO Alternator
Just recone the subs. Its cheaper than risking blowing the amps
And a 14k to each? Holy hell...
Ok I have no knowledge of systems once they get to something of this magnitude but just out of curiosity is this going to be a burp only trick or something that will be for music in a daily situation? Prolly a stupid question but just want to find out either way mad props because that will be one hell of a set up.
its a musical set-up.
josh are those 14k's strap-able? if so just strap the two and run your woofers at 4 ohms if possible.
Start out boxy, shape as you move along.
Dc Audio
Team Fur
28k with 5 D3100's :ehh: 14k to each lvl 5 :peepwall:
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
they're 18volt versions on a 12v system... will never see 14k
Dc Audio
Team Fur
If you are running a system this big, you should be able to Sum things up yourself.
Especially with that money you put into everything.
I would go the route snowdrifter is talkin about.
And I would go below 2 ohm on the amps that are rated at 2.
Things will melt.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
How much would a re-cone from DC run me on average?
1999 Ford F-150
1 Optima Yellow Top
5 XS Power D3100's
Knukonceptz 0 gauge
only DC can tell you that. or a rep.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
pm coming
  • Who's Online   0 Members, 0 Anonymous, 491 Guests (See full list)
