Jason_D Posted January 2, 2012 Report Posted January 2, 2012 right, i have 2 Sundown SAZ 3500's on what will soon be a 14v electrical system, so say 4.5 k per amp. now, do i keep my Level 5 DC's or upgrade to something with a 4" coil? The AA SMD for example. now the SMD will play all day on that power, where as ill have to keep a close eye on the DC's to make sure they dont cook. but the SMD with the bigger coil would be less efficient (i think??) What would be the best way to go? this is for a daily install (well a car i use at weekends and for shows) and it HAS to play music all day long. Any help, advice or experience would be great. Thanks
STEvil Posted January 3, 2012 Report Posted January 3, 2012 efficiency is a product of moving mass vs motor capability. The DC might be more efficient at points where there is less movement, but as soon as you start to require more excursion the SMD is likely to win. Personally i'd just pick what fits your install requirements and tastes: killer lows or solid numbers. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Jason_D Posted January 3, 2012 Author Report Posted January 3, 2012 well killer lows it what im after, so the 4" coil would be better right?
n8ball2013 Posted January 3, 2012 Report Posted January 3, 2012 there is much more to it than coil size. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
armykyle1 Posted January 3, 2012 Report Posted January 3, 2012 well killer lows it what im after, so the 4" coil would be better right? I think the smd will better fit that bill, and its a more musical sub too. You could also look into TC sounds stuff too. LMS 5400 may not take that much power all day but it'll kill the lows. TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
TeamHT Posted January 4, 2012 Report Posted January 4, 2012 there is much more to it than coil size. THIS Tell me...does this smell like chloroform to you?
bass_stalker Posted January 4, 2012 Report Posted January 4, 2012 it goes by size, how many layers, type of materiel that the coil is made of, cooling and making sure that you give it clean unclipped power JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
BeAlLsTaR13 Posted January 4, 2012 Report Posted January 4, 2012 IMO, if you went with the SMDs.. that'll be a perfect power point per woofer Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
Jason_D Posted January 4, 2012 Author Report Posted January 4, 2012 there is much more to it than coil size. care to go into some more detail?
