MrSkippyJ Posted January 8, 2012 Report Posted January 8, 2012 HPF is set around 225 hz the low end of the freq response is 220 should i turn it up to around 300hz and i agree that it is not ferro anymore, im going to have to really look around my doors and see whats going on in there Your HPF is set to 225? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
kirill007 Posted January 8, 2012 Report Posted January 8, 2012 I don't know those speakers, but it looks like they are midranges and not midbass speakers since the surround is barely there. THey probably can't handle that much power at such low frequencies. Put your LPF to 500 and set it to 24db instead of 12db. Maybe then they will handle the power. But where do you get your midbass from? Thinking is the root of all problems... You ALWAYS get what you pay for.
david in germany Posted January 8, 2012 Report Posted January 8, 2012 Is it me or do thos have no roll on the surround. That would explain why the cone is damaged as well.
kickass audio Posted January 8, 2012 Report Posted January 8, 2012 Ferro fluid is only for tweeters. Plus i know for a fact your midrange does not have ferro fluid into it due to the phase plug. The little area outside of your phase plug (the silver bullet shaped object toward the middle of the speaker) has a gap and that gap is where your coil is. There is not anything between the gap to protect it from having water get into the speaker so you probably have some water getting into the door and hitting right onto where the woofer is. I was lucky with my door speakers stock location on my envoy that they had a plastic cover on the rear of the door speakers mounting bracket to help protect it from water. Also it looks like you are over powering that speaker with the crumple marks around the entire cone. How did you set the gains? And for your crossover it should not be up into the 250's, it should be set to highpass around 80Hz and preferably a crossover point of 24db on the amp to help protect from low freqs hitting the midrange and blowing it out. If the cone is still movable and doesnt crush in at all when you play music try to clean up the phase plug and car and wash that side of the door down with some water. Like shoot some water directly at the window. Then open your door on the car and look at the bottom of the door. There are small holes that allow the water that enters your door to escape and be drained out if these holes are plugged with dirt you need to clean them out. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
triplec19 Posted January 8, 2012 Author Report Posted January 8, 2012 mid bass i have a set of rockford t2's and i will make those changes to the crossover and hope they last a lil longer, will these speakers eventually blow with those creases?
david in germany Posted January 8, 2012 Report Posted January 8, 2012 There is no way these will work in a car environment.. You are trying to use them as a mid range ( I know they are listed as a mid range) in a car where the typical speaker can handle 70hz and up. Not these, they are for home systems combining a woofer, mid bass, mid range and tweeter.. Get a different mid. http://www.amazon.com/gp/product/B004BVFJVE/ref=pd_lpo_k2_dp_sr_3?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B004AVYE7U&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1AXBX8WR3941014QAEND
david in germany Posted January 8, 2012 Report Posted January 8, 2012 By the way guys, it is spitting fluid . Read the specs I posted above.
triplec19 Posted January 8, 2012 Author Report Posted January 8, 2012 Ferro fluid is only for tweeters. Plus i know for a fact your midrange does not have ferro fluid into it due to the phase plug. The little area outside of your phase plug (the silver bullet shaped object toward the middle of the speaker) has a gap and that gap is where your coil is. There is not anything between the gap to protect it from having water get into the speaker so you probably have some water getting into the door and hitting right onto where the woofer is. I was lucky with my door speakers stock location on my envoy that they had a plastic cover on the rear of the door speakers mounting bracket to help protect it from water. Also it looks like you are over powering that speaker with the crumple marks around the entire cone. How did you set the gains? And for your crossover it should not be up into the 250's, it should be set to highpass around 80Hz and preferably a crossover point of 24db on the amp to help protect from low freqs hitting the midrange and blowing it out. If the cone is still movable and doesnt crush in at all when you play music try to clean up the phase plug and car and wash that side of the door down with some water. Like shoot some water directly at the window. Then open your door on the car and look at the bottom of the door. There are small holes that allow the water that enters your door to escape and be drained out if these holes are plugged with dirt you need to clean them out. So i should lower the HPF to 80 and use 24db? Even though the range starts at 220 or so? I set the gains by ear trying to find a DD-1 or a shop that has the right equipment.
david in germany Posted January 8, 2012 Report Posted January 8, 2012 Ferro fluid is only for tweeters. Plus i know for a fact your midrange does not have ferro fluid into it due to the phase plug. The little area outside of your phase plug (the silver bullet shaped object toward the middle of the speaker) has a gap and that gap is where your coil is. There is not anything between the gap to protect it from having water get into the speaker so you probably have some water getting into the door and hitting right onto where the woofer is. I was lucky with my door speakers stock location on my envoy that they had a plastic cover on the rear of the door speakers mounting bracket to help protect it from water. Also it looks like you are over powering that speaker with the crumple marks around the entire cone. How did you set the gains? And for your crossover it should not be up into the 250's, it should be set to highpass around 80Hz and preferably a crossover point of 24db on the amp to help protect from low freqs hitting the midrange and blowing it out. If the cone is still movable and doesnt crush in at all when you play music try to clean up the phase plug and car and wash that side of the door down with some water. Like shoot some water directly at the window. Then open your door on the car and look at the bottom of the door. There are small holes that allow the water that enters your door to escape and be drained out if these holes are plugged with dirt you need to clean them out. So i should lower the HPF to 80 and use 24db? Even though the range starts at 220 or so? I set the gains by ear trying to find a DD-1 or a shop that has the right equipment. No, you need a 12 or 24 db high pass set at 220 and above for these but they are designed to be used in a home speaker cabinet, not the pannel/door of a car.
DTS909 Posted January 8, 2012 Report Posted January 8, 2012 I was getting water on my rockford componets when I would wash my car. The window rail is very close to the speakers, had to put some thick plastic over the top of the speaker hanging down on the in side of the door panel to keep the water from getting on the speaker. VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
