Subwoofer flexxing
carshateme
its said that the sub flexes much more in sealed box than in a ported one....
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
Hard to tell, but did you go from 2 drivers in the sealed boxes to 3 drivers in the ported box?
the 2 subs are in a sealed box. the 3 subs are in a ported box
and that is what I thought, I just wasn't sure about it.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Yeah you changed 3 things, enclosure, amp and number of subs. Any single or combination of those things will result in what you are noticing. What ohm are the subs and how are they wired?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
check your sub sonic filter on the hifi.
and check your rcas make sure both are plugged in.
is the ground good?
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
They are a dual 6 ohms. I have all 3 parallel wired at 1 ohm to the amplifier. The gain is set at 0. HU is at -4 bass dB, +10dB sub
The sub sonic filter is set at 35hz, rca is good, ground is good.
how did you have them wired to the kenwood?
1.5 ohms bridged to the amp
Out of phase?
shouldn't make them move less, if anything they would move more. I know a lot less about how enclosures work but it would seem to me that all the subs moving in the same direction would create a certain amount of pressure to help control the cone, where as a sub moving in the opposite direction would lower the pressure and there would be less cone control. Maybe it doesn't work like that though.
But the wiring it self would not cause a problem in how much they move.
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
