I thought the power them the ground but I like to triple check my stuff with the fuses out.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
the only way you are going to get sparks is by completing the circuit. meaning you have a ground touching a power somwehre.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Why do you have a negative coming off alt?
mechman recommends grounding the alt with a wire aside from the grounding it gets from the bracket, they even put an extra bolt to do it from.
if you hook up ground frist then go to add power and it sparkes you take the power off no more sparks.. if you have power on frist and something grounds out guess what its a lot harder to stop.. if hooking up power frist if something grounds out when you already have a few powers hooked up how do you disconect fast?
Edited by Team Bassick (ALPINE)
that's the thing, itdid it before even making contact with the battery those select grounds were going to. I didn't even have it in contact with the battery. (refer to the picture)it did it when the grounds touched when i was going to hook them up.
Edited by ChevyBoy95
is your front battery even grounded?
it has grounds, just forgot to put in the picture. they were not hooked up to the battery during the fireworks show.
You connect the positive first because it changes nothing by hooking up the ground first you have now given the battery a circuit and is now considered "hot". The reason why any battery would spark while connecting the ground is because somewhere in the circuit something is drawing power, whether it be the dome light because the doors open or the simple constants to clocks and radios. All of those things would cause the battery to spark a little at connection.
you win some, you lose some
  • Who's Online   0 Members, 0 Anonymous, 2535 Guests (See full list)
