Say I have a d1 sub and an amp that is only stable down to 1 ohm. If I want to run it at 1 ohm, could I use 2 resistors in the place of the voice coils of another sub? If so, what sort of resistors should I get (or would any old 1 ohm resistor work?)
2005 Honda CR-V
AQ HDC315-A
Hifonics BRZ1700.1D .5 Ohm
4.4 ft^3 box
Kenwood Deck
Big 3
XS Power D5100R Starter, D975 Rear
dude recone the sub to proper coils or just wire to .5 ohm if your amo can take it! But the size of the resistors to increase impediance and the amount of heat it would give off would not be practical. just get right equoipment.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
just wire ur sub to 2ohm
everyone is so stuck on 1ohm
im runnin an old ass power acoustic amp at 2ohm and it pounds hard and is tight
dont hate on 2ohm just run it lol
There use to be a device called accumatch by stinger I think that allowed you to do that... pretty sure it was limited on how much power you could use though...
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Ray is right the accutech did that. Of course it was stupid expensive power limited and I havent even seen any in use in a long time.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
N8 I think we just gave out our ages... I know I'm old lol.....that was back in the 90s when soundstream was based out of folsom ca.. I use to drive to there door and get replacement tweeters from them..those were the good days..the accuvolt or accumatch... would allow the amp to see a certain ohm load constantly regardles of vc configuration... google it my friend
Edited by dc98hoe
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
You could also just wire one voice coil. Using a resistor would just be wasting any "extra" power anyway.
You don't want to wire just 1 coil of a dual coil speaker, if that's what you meant.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
probably because he wants more power....
but recone sub, safest way.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
plus you gotta think, that resistor would be dissipating half the power as heat. So say its a 1000Wrms amp, and you do a 2 ohm resistor in parallel with the sub that's wired in series for 2 ohms to get one ohm. That resistor would be dissipating 500 watts ideally, so that resistor would have to be the size of 24oz monster bottle/can. Just wire the sub @ 2 ohms.
EDIT: Or do as Larry suggested too and get a recone.
Edited by Lbox88
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 3181 Guests (See full list)
