Alex K Posted March 24, 2010 Report Posted March 24, 2010 Instructions dont really make sense, but you have a positive going from the altenator to the batterie, then you have a ground going from the engine block to a grounding spot, then a ground from the negative side of the batterie to the grounding spot? Is this right? + post on battery terminal, to the + spot on your alternator. Straight run to it. Ignore factory wiring. You can fuse it if you want. - Post to any metal part of chassis Chassis or - termainal to engine block. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
lockdown801 Posted April 9, 2010 Report Posted April 9, 2010 Wow I finally made it through this thread. haha So I have question for any one running dual batteries. I have a Dodge ram cummins and it comes stock with dual batteries. It has a ground from each battery to the engine block. Should I replace those or just keep it cheap and run a single ground from engine block to chassis and keep those other 2 wires stock? Thanks
VeRMaxT Posted April 19, 2010 Report Posted April 19, 2010 the big 3 is a simple upgrade so everyone can do it
Alex K Posted April 28, 2010 Report Posted April 28, 2010 i used to think it was the hardest thing in the world xD 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
dunkoholic Posted April 29, 2010 Report Posted April 29, 2010 Good Big 3 tutorial vid( no not a expertvillage vid, they suck) It's a EXO production.(lookup EXOcontralto on youtube.) <object width="425" height="350"><param name="movie" value="http://www.youtube.com/watch?v=<object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>"></param><embed src="http://www.youtube.com/watch?v=<object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>" type="application/x-shockwave-flash" width="425" height="350"></embed></object> that dude is funny! The Project!! 1954 Trunk Build http://www.stevemeadedesigns.com/board/topic/102529-1954-chevy-belair-trunk-build/ ----------------------------------------------------------------------------------- The Daily!! Head Unit: Alpine 9883 Subwoofer: 2 12's DC Level 4 XL Amplifier: New DC 3.5 K Rear Center Console: 1 8' DD 1508 Amplifier: Rockford fosgate 500 Mids and Tweets: Beyma tweets e36 Trunk/Subwoofer Build http://www.stevemeadedesigns.com/board/ind...showtopic=27903
imupabove Posted May 1, 2010 Report Posted May 1, 2010 adding aftermarket terminals on battery post make any difference? i have the big 3 done but the stock terminals (nut posts). so my positives are laying on top of each other. i was wondering if i bought battery terminals, do i just simply remove the stock terminals and put them in the new battery terminals, would this damage the "ECU"? iDA-X200/Clarion EQS746 RF T500-1bd (2) 12" RF HX's Kicker 350.4 Alpine & Polk Speakers Stock electrical
InfiniteRuckus Posted May 7, 2010 Report Posted May 7, 2010 + post on battery terminal, to the + spot on your alternator. Straight run to it. Ignore factory wiring. You can fuse it if you want. - Post to any metal part of chassis Chassis or - termainal to engine block. see thats what i was slightly confused about at first. seems there is a few ways to do this (from what i've been reading & seeing around the internet). some show the negative battery terminal with 2 wires(1 to the block & 1 to the chassis) & some show 1 line from the battery terminal (first from the battery to the chassis, & then one directly from the block to the chassis and not to the battery). what threw me off was that it appears 2 wires need to make contact threw either the aftermarket battery terminal, or a ring terminal connector on the chassis. in my case i have a side post battery, so i need to attach ring terminal connectors to all my additional wires that attach to the aftermarket battery terminal. adding aftermarket terminals on battery post make any difference? i have the big 3 done but the stock terminals (nut posts). so my positives are laying on top of each other. i was wondering if i bought battery terminals, do i just simply remove the stock terminals and put them in the new battery terminals, would this damage the "ECU"? aftermarket terminals are usually plated with metal that resist corrosion better. some claim better contact... i can't verify this but they look pretty clean under the hood. it's really easy to change them out. i personally would cut off the old wire with the terminal & strip off some fresh wire & insert it into the new battery terminal. tighten down the wire & repeat on the terminal. just don't cut the cable too short... cut it closest to the old terminal as possible. it's just like disconnecting the battery & reconnecting it... no damage to anything.
tomypg Posted May 10, 2010 Report Posted May 10, 2010 Just did this in the dark! So easy and took all of 5 mins to install. Car starts quickly, going to be testing it out tomorrow morning. 1988 Honda City E Big 3 in 1/0 Venom 6x9 Venom 6.5 Components Response 4x100 midz and highs amp Fusion NV 2500.1: STOLEN 2 x 12 inch fusion nv subs 10 inch 5 doller subs in my doors PM me if you want help with electrical
carlosg_313 Posted June 2, 2010 Report Posted June 2, 2010 so you have to have a fuse, (so since i think my alt is rated 80 amps, i got to have a 80a fuse) between the alt and the battery? How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman
