SQMonte Posted January 31, 2012 Author Report Posted January 31, 2012 For the + wire doesn't really matter, since I run multiple runs to the rear battery bank I do it from my front battery cause I can use a toolmaker input with multiple inputs and makes it a lot easier. I also ground my rear battery bank to my front battery because I like the complete circuit.Will do, thanksThe way I see it, since the alt is going to the front battery anyway, wire it from there. In MY mind at least, you'd have greater amperage draw ability if you have the alt and battery both contributing on that + wire.Makes sensedo both, 1 from the batt, and 1 from the alt...Wow, wasn't expecting that. Why would it be necessary to do it like that?ive always ran alt to front battery, then back. i would always suggest grounding to the front battery. but you can ground to the chassis and the front battery if you like.I think i'm gonna do like most suggested, pos and neg run from front battery to back. Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
Team_DC-Derrick Posted January 31, 2012 Report Posted January 31, 2012 slight voltage drop between the front and rear batt.. this makes sure the rear batt is getting the same charge as the front, i also connect the front batt to the rear as well i have 5 runs of power total, 4 from the alt, for each of my back batts, and 1 from the front batt, even ran 3 grounds, 2 from the alt, and 1 from the front batt to the back, and grounded the batts x4 in the back overboard, i know.. but i wanted to make sure nothing could go wrong, if front batt took a shit, rears would continue to stay charged The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
carshateme Posted January 31, 2012 Report Posted January 31, 2012 slight voltage drop between the front and rear batt.. this makes sure the rear batt is getting the same charge as the front, i also connect the front batt to the rear as well i have 5 runs of power total, 4 from the alt, for each of my back batts, and 1 from the front batt, even ran 3 grounds, 2 from the alt, and 1 from the front batt to the back, and grounded the batts x4 in the back overboard, i know.. but i wanted to make sure nothing could go wrong, if front batt took a shit, rears would continue to stay charged God that's A LOT of wiring lmao. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
SQMonte Posted January 31, 2012 Author Report Posted January 31, 2012 slight voltage drop between the front and rear batt.. this makes sure the rear batt is getting the same charge as the front, i also connect the front batt to the rear as well i have 5 runs of power total, 4 from the alt, for each of my back batts, and 1 from the front batt, even ran 3 grounds, 2 from the alt, and 1 from the front batt to the back, and grounded the batts x4 in the back overboard, i know.. but i wanted to make sure nothing could go wrong, if front batt took a shit, rears would continue to stay charged Makes sense. I'm def gonna run pos and neg from the front battery to the back, will ride that out for a while and see how it works out. Will run another pos from alt to back batt is needed. Thanks for the explanation, I know what to look for now. Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
MrSkippyJ Posted January 31, 2012 Report Posted January 31, 2012 i think i need to re-learn somethings about electricity and DC circuits. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
carshateme Posted January 31, 2012 Report Posted January 31, 2012 Im just now learning about it. Its the only reason why I didnt input my suggestion. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
HatersGonnaHate Posted January 31, 2012 Report Posted January 31, 2012 i think i need to re-learn somethings about electricity and DC circuits. What all do you need to know or want to know about them? It actually isn't that difficult to understand unless you're trying to do something that hasn't been done before or that there's no possible way to do it. DC voltage is simple to me, AC, not so simple lol My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
MrSkippyJ Posted January 31, 2012 Report Posted January 31, 2012 for starters, why does a battery that goes bad in the front of a vehicle keep batteries from charging in the back if the batteries in the back do not have a direct run to the alt? Also, how is connecting an alt directly to a rear battery band any different than connecting the back battery (or battery bank) to a terminal block located on the front battery? If you have (for example) 2 runs of 0g going from an alt to a terminal block on the front battery, then 2 runs of 0g from that terminal block to the back battery(ies) how is that different than 1 run to the front battery and 1 run to the back? Insert any number of runs, how does it change the charging system depending on which battery they hook up too? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Team_DC-Derrick Posted January 31, 2012 Report Posted January 31, 2012 for starters, why does a battery that goes bad in the front of a vehicle keep batteries from charging in the back if the batteries in the back do not have a direct run to the alt? i never said it did, but i just think it would cause issues well, i mean, if the front batt wont hold a charge, it would draw from the rear batts while its not charging, from my understanding. you have voltage drop going from alt to front batt, to back batt... go out and measure the voltage at the front batt, and at the back batt while the vehicle is charging, its slight, nothing important unless you are anal about it.. and i am, which is why i suggest that The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
MrSkippyJ Posted January 31, 2012 Report Posted January 31, 2012 for starters, why does a battery that goes bad in the front of a vehicle keep batteries from charging in the back if the batteries in the back do not have a direct run to the alt? i never said it did, but i just think it would cause issues well, i mean, if the front batt wont hold a charge, it would draw from the rear batts while its not charging, from my understanding. it would. it would do that either way you connected it. unless you ran a separate charging system for just the front battery, otherwise, it's all connected. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
