does this fuse look okay?
http://www.ebay.com/...#ht_2108wt_1037
Only problem i have with that type of fuse holder is that you have to terminate the wire at the holder instead of having a screw type terminal built into the fuse holder.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
what wrong with that? i dont get why it would be a problem?
Edited by BassMunky
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
because if you gonna change length of the wire, you gonna be wasting terminals
get a fuse holder with wire screw down.
