New battery and amp has no power
he got the battery from advance and they hooked up. the power to the terminal is tight as hell and the in line fuse is still good. i told him to check the remote but he says that is not it.
There's your problem. lol. I bought a battery from them one time, they tighten it down so tight to a point where I tried to remove it and the bolt stripped the inside of the battery....causing a horrible connection. /end troll on advance auto parts.
like said before, Ground, make sure its on a clean unpainted surface, remote, get a DMM and test to make sure there is powering even going through it. Fuse: make sure it isn't popped.
Edited by carshateme
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
use a dmm to check voltage at the amp. if you have power then its either remote or the amp
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
  • Who's Online   1 Member, 0 Anonymous, 1256 Guests (See full list)
