9 Volt Voltage Drop!
All connections are tight
2 batterys
big three done with 4 guage
amp is hifonics 2k (1500ish rms)
stock 110A alternator
whats my problem?
yes i understand this drop is clipping the hell out of my amp and subs im trying to find a solution
voltage goes haywire when subs are on buy when just headunit is on i drop about .5 volts
with no extra batteries you shouldnt drop that low.
Edited by ChevyBoy95
use a DDM at the battery when trying this not that volt meter than post results
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
Dead alt,
use 0ga wire,
bad batteries,
What is the max volume on your headunit? I saw it go up all the way to 55 in the video.
You are trying to get WAY more power from your amp than it can realistically put out. If you dont have a DD1, you should invest in 1.
what type of batteries are you running , and you should have used 1/0 for the big 3.,
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
Ur alternator is probably toast dude, and only 1 run of 4 gauge probably isn't enuff I'd upgrade to 1/0 man!
Go to auto zone, they check out ur alt and test ur batt and alt for fweeee!
Edited by csill420
Fuck warning points.
how are you dropping that much? i have no big three or anything and i'm running one ohm and only dropping to 12.3 volts from 13.6, prehaps run some 0 gauge to help with current?
or maybie a bad ground since that can screw with the voltage
Edited by bass_stalker
if you are in the nines your car should either stall out or be very close to it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 342 Guests (See full list)
