Okay, design for 2 type rs 12s Double baffled.. Does this look fine? or did I totally screw up?
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Your port height isnt tall enough and you didnt enter the number of common port walls and im sure your displacement isnt right either.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
and I think ur baffle thickness is wrong too
Just a few notes, the shared port is twice as thick on the center duct than in it is on the lateral ducts, you don't need the double baffle on this design but if you want to do it then add 0.75 to the depth so you don't go low on internal volume, you need 1.5 cubic feet per sub of net internal airspace (you are low). The T parts you added to the port reduce port area, I believe are not necessary. you need to set common walls to 2, set baffle thickness to 0.75 if you are adding the extra layer.
Edited by Joe X
Okay, so I'm just taking everyone advice it...how does it look now?
number of common port walls should be 2.
and the box is too small
make it taller like the first design, just make the port taller along with the box.
i.e. the box is 15" tall, port should be 13.5" tall, 2 common port walls.
if you're shooting for 1.5 cubes per sub, the box should be ~3 cubes net
Edited by 412 CVX
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
  • Who's Online   0 Members, 0 Anonymous, 1096 Guests (See full list)
