Amps won't turn on. 16 volt system. relay for turn on
irpirate
I guess you could wire the sides of the coil in the relay either way and it will work. So it must be a wiring issue then go back over your wiring.
Keep in mind that some relays have a diode inline with the coil to help keep it from ringing....and that may be his problem. OP, Try swapping your inputs on pins 85 and 86.
The diode is wired in parallel across the coils not series. relay is fine. check wiring
What's voltage at remote wire?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
thanks for the replies guys. i tried switching 85 and 86, nothing. not sure what the remote wire voltage is but i tried jumping the turn on for the relay to a + of a d3100 and nothing turned on.
shitty relay? i bought 5 and have tried swapping them out. nada.
*edit - also talked to dj from team nemesis. said he was running his turn on the same way with a relay. besides his is working lol.
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
The relay only needs 12 on 86 and ground on 85 to turn over or "click"..
Even if its diode suppressed you had it hooked up correctly before.
At this point id say ground if the relay isnt clicking.
If it is clicking then you have a 12v supply issue or rem wire issue to the amps.
So.
Take the wire from pin 30 and touch it to pin 87
If they turn on then its from the relay to the deck
If they dont then just get a dmm already..
Hello all, having a bit of a puzzler. i have 4 sundown 3500s hooked up to my 9 16 volt xp1000s. power grounds are wired up. remotes are all jumped together.
i tried using the normal turn on and nothing.
i jumped the bat + to turn on and everything turns on.
hooked up a bosch style 5 pin relay
30 to 16 volt bats + = to amp turn on
85 to ground
86 to 12 volt turn on/remote wire.
87 to amp turn on = to 16v bat+
87a nothing hooked up
thanks guys!!!
I think you have the above wires bassackwards. Been a while since I messed with a relay but try that.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
It does not matter how those 2 wires are hooked up.
Jesus christ.
Jesus christ.
My bad...
Either have 5 bad relays or ground issues then.
Do you have your 12v bat / 16v bats and the relay sharing a common ground?
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
sorry guys for the late reply. been busy as hell trying to get everything hooked up. ended up pulling the relay off and just throwing a toggle switch on it for now.
i don't have a common ground for the 12 and 16 volt side.
I'll test out what you said when i get the chance ray.
hiiiiiiii
16 12's 4th order
UBL - clicky
  • Who's Online   0 Members, 0 Anonymous, 960 Guests (See full list)
