I was playing y'all don't hear my by meek mill off the dreamchasers mix tape, I guess I'll just turn my gain down a little bit more. I don't drop voltage really at all, with the engine running its steady between 14.4 and 13.9, and I used the dd-1 while my engine was running and my heater on full blast to tune it to with the voltage it would normally run at.
Where are you measuring your voltage at? Amp or battery?
yes always measure at the amp, that way it counts the voltage drop in the wire also.
Edited by Socky
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
The battery, should I be measuring it at the amp?
Absolutely. Try that and post back what your voltage is
try checking the output of your amp with the dd-1 again with the subs still hooked up.
I never did get why they say to unhook your subs to test it, your subs load the amp, the amp draws power, the voltage drops, then the clip ceiling falls and boom.
what was once clean with no load is now clipped to shit.
Not to thread-jack, but I tried this with mine thinking the same thing.. Since you're drawing more power at a lower impedance than you would at twice the said impedance, but nothing really changed.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
just downloaded the mixtape from datpiff...
39hz and 29hz are the main notes in the song. Song is clipped +2db but thats total including mids/highs, either way its a bit clippy :( Peaks are between -10db and -4db
thats why it smelled, voicecoils were getting warm from clipping amp and playing below tuning (which lowers power handling)
