thegr8cody Posted December 7, 2007 Report Share Posted December 7, 2007 im running 2 18's 1500 - 2000rms and i cant decide on amps.i kinda wanna do 2 cause i heard it helps on imp rise.but there all about the same amount. 2 powerbass asa2000 strapped or on per woofer.soundstream pca2000d strapped or one per woofer.power acoustik a3000db strapped or one per woofer.or a hifonics xx colossus? Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
gotFI? Posted December 8, 2007 Report Share Posted December 8, 2007 not a big fan on strapping amps. i would run one amp to each sub. amps to run? heres a hint..........no powerbass amps. Quote Link to comment Share on other sites More sharing options...
mrwigglezdj Posted December 8, 2007 Report Share Posted December 8, 2007 if the subs are dual 2 i would get 2 pa 3000ds and run each amp at 1 ohm youre sure to get 2000 rms out of the amp Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets Link to comment Share on other sites More sharing options...
aquill1 Posted December 14, 2007 Report Share Posted December 14, 2007 You could get a pa 5500d for near the mid 300's....not sure on the accuracy of the rms... Quote Link to comment Share on other sites More sharing options...
Twigz Posted December 14, 2007 Report Share Posted December 14, 2007 Hifonics Crunch Ground Pounder 2,500 rms I think. Quote Fear The Quack! Shot at 2007-08-19 Link to comment Share on other sites More sharing options...
andym85 Posted December 14, 2007 Report Share Posted December 14, 2007 (edited) just remember that strapping two amps that are each 1 ohm results in a 2 ohm load.... i would just do one amp per sub Edited December 14, 2007 by amatt85 Quote i likes me some audio stuff... Link to comment Share on other sites More sharing options...
bigtimedesigns Posted December 14, 2007 Report Share Posted December 14, 2007 (edited) im running 2 18's 1500 - 2000rms and i cant decide on amps.i kinda wanna do 2 cause i heard it helps on imp rise.but there all about the same amount. 2 powerbass asa2000 strapped or on per woofer.soundstream pca2000d strapped or one per woofer.power acoustik a3000db strapped or one per woofer.or a hifonics xx colossus? If your gonna use two amps then run each amp separately to each sub and my choice of amp would be the Fosgate 1500BD amps and they should only be used if your subs are dual 2ohm so you can wire them to 1ohm loads. Edited December 14, 2007 by bigtimedesigns Quote Visit My Website Link to comment Share on other sites More sharing options...
AI James Posted December 14, 2007 Report Share Posted December 14, 2007 id run a XX Colossus before any of the other options you listed, since it is a 2 channel amp that does 1600 per channel and wiring is simple Quote Link to comment Share on other sites More sharing options...
dwright27 Posted December 14, 2007 Report Share Posted December 14, 2007 (edited) run 2 of the collosus bridged at one ohm and get the 3200 per sub. you're running BTLs right? Edited December 14, 2007 by dwright27 Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
AI James Posted December 14, 2007 Report Share Posted December 14, 2007 run 2 of the collosus bridged at one ohm and get the 3200 per sub.you're running BTLs right? i wouldnt bridge a colossus down to 1ohm, i havea colossus in storage that has a soda can sized hole in it from running it daily at 1ohm bridged Quote Link to comment Share on other sites More sharing options...
