to the body? where on the body? that gives thousands of different location possibilities. why isnt it on the frame?
you never said you checked the power wire connections, at the fuse holder etc. that can be the problem too
Picture is on its way.
no big 3
You're still looking for a problem?
you think so? Even on 1000 watts you need a big 3?
its recommended even for the smallest of systems or aftermarket mods. stock charging cable is small as shit (like 10-8 gauge) and is useless for higher power applications.
so go get you a dmm and check your positive and negative voltage at the amp if its not reading almost the same as the positive and negative at the battery,then you have resistance either in your wires or the connections, some wires corrode over time and can cause resistance. if your voltage is only off a little bit this is probably not your problem, but it is a process of elimination.
Edited by Bmike
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
no big 3
I've seen some cars have 1500 rms with no big 3 upgrade and some cars needing big 3 done with 750 rms. It's all about the specific vehicle/situation. Lots of variables....But the big 3 is a must IMO, especially if you're having power issues.
Edited by zack_e89
97 Suburban
8 custom PSI Platform 3 18's
no big 3
Let me say that doing the big 3 is also a safety upgrade too. Figure that a 1000 watt system will draw between 100 and 150 amps, plus the stock electrical and BAM: you have 200+ amps on tiny little wires that weren't designed to go over 100 amps. Hello fire.
no big 3
Couldn't agree with you more....fire in car = bad :diablo:
97 Suburban
as stated check all positive connections to the amp starting at your battery and working back to the amp. even if it "looks" connected doesnt mean it has good connection.. lightly pull on the wires. see if any give. check check again. also check voltage with the truck off and on. and check voltage from battery back making stops between at the posts on your fuse holder.
Make sure none of the wires are getting hot.
And get the big 3 done and out of the way.
You won't have to worry about it in the future.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
  • Who's Online   0 Members, 0 Anonymous, 629 Guests (See full list)
