I would definately look into your vacuum lines james, I had that problem with an eclipse. I got some starter fluid (spray can) and went around the engine bay/ vacuum lines and gave it an occadional spray, and when I got to the line that needed fixed the idle jumped up a bit in rpms.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
MAF Clean it with Carb Cleaner, I had a similar issue in my stang, cleaned the Mass Air Flow Sensor and I was good to go.
i know its a totally different car but when my motor starts doing that i know my Throttle Body needs cleaning.......keep that in mind those with 5.3 vortek or even 6.0
Follow my Tweet (Twitter)
sounds like a plan, considering thats hella cheap. will try that out
last night got around to looking at it a little, while we were parked in idle and the headlights were dimming everytime the rpm's dropped, noticed a ground wire from my battery totally off the post. Reconnected it, and it didnt fix the problem but i think that its an electrical problem of some kind as it gets worse the longer we drive the truck, im beginning to wonder more if its the alternator rather then the little problems previously stated
my ole ladies exploder did that and it turned out to be the plug on the air intake make sure its all the way in and clean
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
