Ok so i fix allll my wiring and stuff and i a listen to music. then everything stops in the back. i got and look and nothings making noise but everytheres on but not playing. so i take it to my audio store and nothings wrong. so i rewire and i notice when i plug in my RCA cable in the little green power light comes on but the words jenson light up as if it were on. all my fuses are fine and wires are plugged in right.. and one knoe whats wrong?... im stumpped
ARC Audio 2 12s
Lightning Audio 1000W Amp
XO-Vision DVD/CD
1994 Grand Prix
use a usb stick if you have one and make a sine wave track in audacity that's a few minutes long and use a dmm and see if your getting ac volts at full volume through the rca patch cords, the volts should match what the h/u is rated for so if it has 2v pre-out then you should see 2v a/c on a dmm.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
what should i check: Ground"ing" wire thats screwed in my trunk or my Ground wire thats wire to my head unit?
ARC Audio 2 12s
XO-Vision DVD/CD
1994 Grand Prix
check your grounds
and stop using "jenson" amps.
all i can afford. and ground wire is the black one in the head unit right?
ARC Audio 2 12s
XO-Vision DVD/CD
1994 Grand Prix
no, he means the one on your amp
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
  • Who's Online   0 Members, 0 Anonymous, 2443 Guests (See full list)
