free box designs with a sketchup pic or file
teardrop
ohhh fine haha
2 DC Level 4 12"s, DC 5k, max dimensions 60" by 34" by 16", 4th order.
1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire
*3 Kinetik 2400s and a Mechman 270A alt in the future*
2 sundown SD-2 12s D4 wiring them to 1 ohm
Amp Saz 1500v2
Max dimensions: don't really have but going in the back of an astro van So plenty
Port Back subs back
Subs specs :
Fs: 38.8 Hz
Re: 8.0 ohms
Qms: 6.18
Qes: 0.69
Qts: 0.62
Cms: 0.09 mm/N
Mms: 195 g
BL: 23.5 NA
Vas: 31.7 L
Sens: 86.1 dB 1w/1m
Le: 4.14 mH
RMS: 500 watts
Tune Hz: 33
ohhh fine haha
any preference tuning wise?
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
34 hz
I guess I was referring to after the tunnel, idk lol I don't know much about 4th orders. My truck likes 45 hz, so tune it to 45 I guess lol.
34 hz
i should mention that 4th orders aren't tuned like regular ported boxes. the sealed side is what helps control excursion, whereas in a regular ported box, excursion is controlled mainly by the port.
tuning between 43-50 hz is pretty standard
More box builds
If you want to do one for 4 m1xls for my 2dr blazer I'd appreciate it, they'll be pushed by two 3.5ks at .7 ohms, they have upgraded spiders so they should be fine, the max width is around 38 inches, the height and length don't matter, I'm losing my back seat so I'll have alot of room, if you get bored I'd appreciate it!
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
2 Kicker Comp 12s wired down to 2-ohms MTX RTP251D pushing 200 watts at 2-ohms Max Dim: 33Wx14Hx28D Both subs and port facing forward from my trunk Random Info: -I'm looking to have the port in the middle of the subs -Looking to be as close to 3.75 cubic feet net after all displacements -I will be doing a removable port, so the original dimensions I'm wanting to have around 16 sq inches of port per cubic foot and then will use 0.5" thick MDF in the removable port that, when inserted, will decrease the port dimensions by 1" on H and W. This should bring it down to around 12 sq inches of port area per cubic foot of box. -I'd like to use the 33Wx14H and have 0.25" of spacing around each sub and a 5" wide port in the middle of them. So 12+12(subs)+(0.75*4 for each piece of wood going deep)+(0.25*4 spacing around each sub)+5" port=33W -Would also be 12H for each sub + (0.25*2 spacing) + (0.75*2 wood thickness for top/bottom piece)=14H -Been trying to tinker around with the equation all morning, I'd have to keep it to where there's no bend in the port if I'm looking to have a removable port. If you can help with this then cool! EDIT: Forgot to add that I'm looking for a low tuning with the removable port in, so probably around 30Hz and then a bit higher of tuning when it's not in.
ill get started on it and see what i can come up with
Cool deal man, I've been trying to work on this thing all morning and it's got me stumped. I was hoping for a tuning of around 30Hz with the removable port in and somewhere near 40Hz(prob just under) without the removable port in. I've kept running into the problem of needing a port bend to make this happen though >.>
i need sub displacement. man with a square port i cant come up with nothing sorry i can with round ports but not square
