Can too much voltage drop fry your amp?
I have heard a lot of people saying that if you let your voltage drop too often or too much it can cause your amp to go bad after a wile. Is this true??
- 2003 Jetta GLi VR6
- Kenwood HU
- MTX 9500 12''
- Soundstream Rub1.2500
To much yes I could see how that would hurt it. Start at 14 and drop to 7 if the amp didn't shut itself down before 7. But dropping a lot as long as its not below 11.5-12 I don't think it would "technically" lessen the life of an amp.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
IIRC it has something to do with the efficiency of the mosfets within the amplifier. More voltage drop = less efficiency = more heat/strain on them which in turn causes clipping.
think of it this way
you need food to work
the harder you work the less food you get. eventually it will catch up to you and you will get weak. but your boss is an ass and makes you work hard still.
will you get weaker?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
An amp with a regulated power supply will work to supply the amp with a constant and stable supply.
If the voltage drops, then the power supply musty draw more current to keep the same power level (V * I = P).
The power supply mosfets all have internal resistance so the more current that goes through them, the more they heat up.
I^2 * R = P. Power loss through heating increases with current squared so small increases in current will induce a big increase in power loss.
To the point....don't let your voltage drop.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
  • Who's Online   1 Member, 0 Anonymous, 1948 Guests (See full list)
