35k at 18v whats it gonna do at 24v just plain WOW
2000 stratus10 SunDown E-10s
Singer 250amp Alt
Xs Power D975Concept c2400All 0 gauge wire10 6 1/2's in Rear Doors
brb gonna put 2 of these on a ddz and make my way to 184dubs
who would really need this much power out of 1 amp..id like see steve try it see how he gose for voltage (asume he would be fine, and that they could build it run 14v and still get 35k) and see how it sounds lol
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
I'm surprised people aren't ripping on it since its rated what it does at 18 volts, like other amps.
wow.... im surprised with that much power it still only has (4) 8 gauge outputs.... i would expect AT LEAST (4) 4 gauge outputs from this....
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
... NO way is this a T15k Killer... you only need like 300 amp to power the T15k to full power... this thing says 1750 amp?
300A is only good for ~4400w. If you want to run the t15k at real full power you need a minimum 1034A.
That said, yes, most of us would not run the amp at "full" power for very long and that is why 300A is sufficient (on average) for the average user.
Hammerdown... 1%
  • 4 months later...
not to bump an older thread.....but /\ this...... i believe if i read correctly the t15k uses the same technolodgy as a defribulator so it pulls only 300a at all times.....its not like a normal amp.....it uses "hybrid" technolodgy i also read that the power supply for the amp is good for 5000w just itself.
i would like to see proof of this amp needing more than 300a of current at full tilt...... i think this is one of the best looking amps ever built..... not tryin to rip on you just keepin facts facts......
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
300A will not power the T15K to full sustained power, only average peak use.
Hammerdown... 1%
