Basson50 Posted April 3, 2012 Author Report Share Posted April 3, 2012 i believe he said 2 sundown 3500s strapped at 1 ohm.. he made another thread like 5 mins ago No there strapped @2 ohms now , and I wanna strap at 1 Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted April 3, 2012 Report Share Posted April 3, 2012 Either bad connections, more draw than available at idle, or a combination of both. It isn't really rocket science. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Loslam Posted April 3, 2012 Report Share Posted April 3, 2012 (edited) If you have room under the hood get another alt before batteries imo Edit: ^ in regards to your electrical question post Edited April 3, 2012 by Loslam Quote 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/ Link to comment Share on other sites More sharing options...
Basson50 Posted April 3, 2012 Author Report Share Posted April 3, 2012 If you have room under the hood get another alt before batteries imo Edit: ^ in regards to your electrical question post One thing I wanna do is put two kinetik hc 800s upfront instead of the optima and maybe one more hc 2400 in the back in another two more runs of 0 guage. Quote Link to comment Share on other sites More sharing options...
Loslam Posted April 3, 2012 Report Share Posted April 3, 2012 That would improve your battery bank, but you can only go so long drawing more than what you can produce. Also causes more stress on alternator if it's at full output all the time trying to keep up = shorter alt life Quote 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/ Link to comment Share on other sites More sharing options...
Slapuhho Posted April 3, 2012 Report Share Posted April 3, 2012 I would kill for 12.8 at idle.. Quote 4 18's, low power and lots of gay fur. Team gg Team DOA My Videos Link to comment Share on other sites More sharing options...
AA98hoe Posted April 3, 2012 Report Share Posted April 3, 2012 Step up to 14v and you will never drop into 12s unless you want too Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
Ballen194 Posted April 3, 2012 Report Share Posted April 3, 2012 12.8 full tilt at idle doesn't sound bad to me. Rev it a little if your worried. Quote 98 Isuzu Rodeo Pioneer Deh-6300ub SUBS*Upcoming* SSA Xcon 18 4th order AMP Banda 3500 Mids/Highs Pioneer EQ Clarion EQS746 ETC. Two 1/0 run's KnuKoncepts 1/0 big 3 Shuriken BT-100 under the hood Shuriken BT-120 in the back Link to comment Share on other sites More sharing options...
MECHMAN Posted April 3, 2012 Report Share Posted April 3, 2012 You are exceeding the available power from the alternator at idle. If your vehicle needs 40-80a just to operate at idle you do not have enough power to lean on it at idle. This is why we don't recommend playing at idle, it will drop the voltage in your battery bank and add stress to the alternator from running at max output at low speeds. Maintaining 12.8v with your system actually is good considering your vehicle and system will draw more than this alternator can produce at any speed. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
Sanitarium Posted April 3, 2012 Report Share Posted April 3, 2012 You are exceeding the available power from the alternator at idle. If your vehicle needs 40-80a just to operate at idle you do not have enough power to lean on it at idle. This is why we don't recommend playing at idle, it will drop the voltage in your battery bank and add stress to the alternator from running at max output at low speeds. Maintaining 12.8v with your system actually is good considering your vehicle and system will draw more than this alternator can produce at any speed. This. When i dropped my amps to 1/2 ohm and realized i was only dropping to 12.8v full tilt, i was actually happy. Don't get alarmed till you start dropping to 12.0 (turn it down) Quote Link to comment Share on other sites More sharing options...
