Is it possible to modify a stock alternator to achieve a higher output? One of my friends talked about how he just did this to his Toyota Celica, and I was wondering if he's blowing smoke or not...
2001 Toyota Corolla CE:
4x Crescendo PWX6.5's
2x Crescendo FT1-SE's
1x DC Audio lvl 2 M1 8 (looking for more)
Slot port box 0.7ft^3 @ 31.77hz
Rockford Fosgate R750.1
1/0 Knu wiring all around
Looking for XS Power D1200
example a mla module will boost voltage too
gm also sells A "voltage booster..ups it by .4 of a volt )
and xs power sells a vcm for chevys thatll up voltage too
but i call bs in his story lol
Yes it can be done... Reliably? Not really.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
you can always get your stock one rebuilt, or wound tighter. yeah it will probably get you maybe 50 more amps, but how reliable... idk
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
it is dueable swapping out the diodes n shit
read here
R.I.P!
(Nov-29-2009)
92 explorer
current build
Depending on the alternator case you can buy a high output rebuild kit, but as stated it wouldn't be as reliable as purchasing a well built alternator.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
you can get a stock alt rewound for higher output my buddies has his 60 amp wound up to 220 amps and has been good for over 4 years only problem it puts out nothing at idle only at 1500 rpm and up
sorry folks i CANT read today getting more amps out of a stock alty.. yes it can be done
i was thinking higher voltage lol
i lost my glasses today and cant see shit so im depressed and hi as hell
So the story is half true, half bs? Lol I knew it!!!
Anyway, if this is the case (no pun intended), my aunt worked at Richmond Electric here in Wichita. From what she told me, they hand-wind alternator windings and can custom make their own diodes for commercial and recreational use. I can get this done dirt cheap, and it'll help out in the long run until DC starts producing the 320A alt for my car!
  • Who's Online   0 Members, 0 Anonymous, 2044 Guests (See full list)
