I don't know if 90's are considered vintage but here's what I have (pictures suck)
My Kenwood KC-X1 6 channel Preamp
And the matching 50 pound beast, the Kenwood KM-X1 6 channel (not 5.1) Power amp. 100 watts rms at 6 ohms in 6 channel mode at 0.02% thd, 130 watts rms at 8 ohm in stereo mode at no more than 0.03% thd, 65 watts at .0015% thd on 1khz. Also has a sub channel to power passive subs. This thing screams clean power
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Keep going , this is interesting ! Haha my first system was the mtx terminator 2 12's and terminator amp. It sure gave a bang for the buck! But it's long gone in the car accident I got into last June :(
So how you might want to get it working is first plug it in to see if it works,
If it doesn't work check if the fuse works.
If it does, your input will have to be an RCA. Chose the speaker that you want to use, find out its ohms, then set the ohm selector to the proper ohm(age) then set the 901 or other to other since you wont be using the Bose 901s.... that should work. I would recommend starting the volume at minimum and work your way up.
Im a broke student. still manage to have a pretty good system though.. (at least i think)
Nice, it can be considered what ever you want, nice.
That is a pretty good system for your first one, better than mine.... i have two Pyle plw10lb ($30 each) both were free air into the trunk.
Are you OK from the car accident?
it doesnt work but i did plug it in to see. fuse wouldnt come out tho. i really wanna get it going tho
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
This is the most powerfull amp i have.
Vintage CLEAN power.
http://www.allegroso...nsui_B2101.html
260W at 8 ohms per channel (it's a 2channel.)
350W at 4 ohms per channel .
Both of those numbers with only 0.003% of THD.
These are some serious numbers.
You can go to 1% THD before the amps goes into protection mode, just before that point it makes about 320W at 8 ohms.
ANd yes you can bridge this beast.
All class A/B power.
Impressive amplifier you got there
2003 Kia Sorento
Team Subsonic Lows
Agreed, what do you use it for currently?
