Well, I will be hooking up my new BC3500's when the weather gets nice again. I am running 2 Fi N2 15's (Dual 2) and want to know if I should strap the crescendos or have them seperate? I was planning on running each woofer paralell to each amp at one ohm with 2 positive and 2 negitive runs to each woofer but if I strap them it would change everything? If I dont strap them, what is the best way to gain match? I don't have a cc-1 only a dd-1. Thanks
I have my dual 2 ohm subs strapped on two 3.5k's.
I have each woofer wired to 4ohm and then the final load on the strapped amps is 2ohm.
Ok. well that answers that. they only make around 1975 watts each @ 2 ohm. I would want more than that so I guess i'll run them seperate. anf figure out this gain matching deal. Also anyone know if you can use one remot eknob with a splitter with these amps?
Why don't you just strap them @ 2 ohm...won't need to worry about gain matching (unless you buy a CC-1) and won't have to worry about a splitter to use a single remote knob
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
because they are only stable at 2 ohm when strapped. I want to run them each at one ohm I dont want a 3500 watt amp putting out 2000 watts. and its more straight forward to wire when they are seperate? I hate having 2 wires crammed into one terminal. I would like them strapped, but i though I could just strap them so each one was paralell to each woofer but I guess not. I don't see why they can't make amps that allow you controll both without strapping. I'm lost
Edited by Amart88
if you strap at two ohm each amp sees a one ohm load. you are way overcomplicating this. if you strap at one each amp sees .5 just strap the amps.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Wire a pos from one coil to a negative of the other coil. Do that for both subs.
Wire the two remaining positives to the positive of the master amp.
Wire the two remaining negatives to the positive of the slave amp.
Connect the two ground terminals of the master amp to the two ground terminals of the slave amp.
Run your RCA to the master amp.
Run your bass knob to the master amp.
Connect one side of a RCA from the Master to the Slave.
Switch Slave amp to Slave.
You shouldn't have two wires in one terminal if your strapping.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
You do know when 2 amps are strapped at 2 ohms...each amp sees 1 ohm right? You should do some more research on how things work before you go playing around with "7000" watts before you blow shit up.
Have you even opened the manual or looked at specs? Clearly states 7000 w rms strapped @ 2 ohm mono...
Edited by BeAlLsTaR13
Team Sundown Audio
  • Who's Online   0 Members, 0 Anonymous, 3062 Guests (See full list)
