STEVES TAHOE box questions
Are you not listening. It won't work for xxxs hell its not even ideal for what he's running now.
His box now was built for the BTLs right? and yeah buddy if i were you i would hit up a designer and have a box built to match YOUR subs so you will have max output.
I think he said he originally built that box for 4 RE MT's, then he put BTL's, then the SMD's. I also remember him mentioning that he wanted to rebuild a new box for the SMD's
Though I also agree that the OP should have someone design a box for those XXX's
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
if you can't comprehend anything else off of this thread, refer to my last post on page one.
i've done extensive research on the RE Audio XXX series.
and I'm telling you what each sub likes.
the 12's like ~4 cubic feet. 15's like ~4.5 cubic feet. and the 18's like 6 cubic feet.
yes that is per sub.
if your going to run 4 18's, your best bet is to build a CUSTOM box that ~24 cubes.
but you need to make room for the massive 54mm one way xmax.
so, long story short, stop being retarded, make up your own build, and take advice before you throw money at people to "makez mah shits dew duh deebeez >9000"
pretty much already gave him a foreground for a box build.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Everyone wants to throw 4 18s in there an thinks it will sound good...I played with 2 15s then 2 18s for a long time before goin with 4.... I won't give you my box dimensions and I doubt steve will...its trial an error ..what works for me may not work for you..even if I gave you exact dimensions I doubt it would sound good.different subs an power...goodluck to you though
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
didnt he also have to move the rear seat forward 2 inches to get it to fit?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
he's not going to give it out....take the measurements(easy) and contact a designer to come up with something for you
he doesnt have to give out the measurements. there are some good pics of this thing out there, and i do alot of work in reverse engineering. a clone of that box is easy. a good pic is all i need, and there are alot of them out there. lol
Owner of BigAss Ports
You thought the smd's would be 3500 apiece?
I don't think you got dropped on your head as a baby... I think your mom drop kicked you out the window and you got hit by a passing bus.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
:rofl::lol: This is so fucked up! :D:santa:
Edit: welcome to my sig
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
