Ok I kno alot of people including myself wire the subs at 1 ohm for less resistance which equals more power...is it a good thing to always run at 1 ohm or is it better to run the same amount of power at 2 ohms...does 2 ohms give u a cleaner sound? This maybe a noob question but I wanna know the pros/cons of running at 1 ohm rather then 2 ohm...
Same amount of power on 2 ohms.... It is less strain on your electrical setup.
And not all amps are 1 ohm stable, so if you run them at 1 ohm, they have a tendency to get hot, and increases the chances of making some magic smoke.
I on the other hand don't give a fuck and I run mine at .5 ohm. Bitches love .5 ohms ;)
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
would it actually be less strain? I mean significantly less strain?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Running at .5 is dangerous for your amp, so I would recommend not doing that lol. But the less resistance you have, the more power you get out of the amp. But the more power that it puts out, the more heat it creates... Too much heat = fried amp internals.
That's why you see amp ratings like this
1600 watt amp
4 ohm - 800 watts
2 ohm - 1200 watts
1 ohm - 1600 watts
I doubt a significantly less amount of strain, but a less amount of strain nonetheless.
To ohms will sound cleaner most of the time and most of the time you get less thd (total hermonic distortion) less current draw (less strain part) and less heat (heat is a killer to all things car related from the motor to your voice coil and amp)
BUT not all amps are created = some are drity shitty no matter what
If I could get the power I wanted I would run at 8 ohms but you get like no power at 8 ohms
Safer to find an amp that will push the power you need at 2 ohms.
And I disagree with the notion that running at 1 ohm gets hotter than getting the same power at 2 ohms. I mean, basic laws state lower resistance = more heat, but in the traditional sense of the word, class d amplification technology doesn't get hot. And if it is, then something is wrong :good:
Edited by TeamHT
  • Who's Online   0 Members, 0 Anonymous, 1070 Guests (See full list)
