Been reading your thread for nearly 2 hours. Crazy ideas and sick job. Well done. :drink40:
Keep up with the good work. Gonna keep an eye for updates.
Yeah.. Wicks is "one of those" ..lol
although, thats a shitty break.
Means alot of work, and alot of missed time... Time repairing instead of improving.. blows for my man...
Means alot of work, and alot of missed time... But Time repairing equals upgrading and improving.. congrats for my man...
Fixed that for you buddy! If he has to repair it, might as well make it sexier!! RIGHT?!?!?
Hey this is just a suggestion if you go to rebuild or replace that baffle on how to attach it.
Im not sure how you did the joint there, and not sure at what angle the baffle mates with the bottom piece of the enclosure, BUT have you though about doing a dado on the bottom and haveing the baffle fit into it. More surface area for the glue to bond, and even on mdf/plywood butt joints are not as strong.
Your build is top knotch man, I enjoy it alot and you seem to be great at figuring out problems, but figured I could share a thought.
If you have an angle that is not too sharp, like 10* or even more like 25* where the baffle meets the bottom (I'm not sure I did not look back) You can make a jig for your tablesaw that would allow you to cut dado or rabbit joints at a shallow angle. Hit me up if you want help doing it.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
After about a half hour of reading or so...
DAMMMM manye!!! Install looks sweet!! Here in Denver would love a demo... :drink40:
Thanks Dude!
Hell yeah, I'm always down to meet fellow bassheads in Denver.
Although at the moment my entire trunk is gutted due to my recent discovery so I can't do any demos in the near future, but after I get things patched up lets talk.
:good:
Jesus Wicks. Good carnage.
Indeed Sir! :o
I figured a 1.5" double baffle glued to the base-plate would be plenty, but obviously I greatly underestimated the viciousness of those XL's, especially on 5kW and in a relatively smaller box....
"Live and learn, live and learn...."
I can't get mad about it, I just have to roll with the punches and adapt.
Thanks for checking out the build and the comment, much appreciated!
:good:
Friggin' THIS ^^^ :D
One step forward and two steps back.....
LOL, I already had some sexy plans for the baffle and this delayed my progress quite a bit.
So now I have to reinforce the baffle while still keeping everything the same dimensions as before....
You'll see why in future updates... ;)
That's EXACTLY what I should have done (dado on the bottom plate)..... :Doh:
The baffle angle from the bottom is 67 degrees.
You can bet that I'll never do a simple glue joint on an angled baffle again... :D
Right now I'm just going to try and reinforce the joint as-is. Anything else more elaborate would basically require me to tear the entire box out of the trunk and start over since its built inside the trunk and all glued together. Taking the front baffle off would probably mean destroying the box.
I put a LOT of time and effort into this box so I want to try and utilize it as much as possible.
Thanks for the comments and suggestions, good stuff and always welcomed!
:drinks:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
In case anybody's interested in the current mess that I have, here you go:
Had to gut the trunk and peel my 54lb XL's out of this box which was no fun task at all....
In order to add some fiberglass reinforcement to the bottom edge of the box, I needed to remove some material so that the front of the baffle stays flat (you'll see why in later updates)
Rather than use a chisel and hammer for hours and hours, I bought one of these neat little saws that I've been looking at for a while.
Did a great job of digging in about 1/8" and removing a thin layer of MDF.
What a mess...
I also used the saw to dig under the baffle and remove some of the old glue in between the MDF pieces.
Then I countersunk some pocket-holes so that I could screw the baffle down to the bottom plate.
Based on some previous suggestions, I picked up some TB2 to try out instead of the TB3.
I made sure the pocket-screws were long enough that they would go all the way through the bottom plate and secure the two pieces together well.
Here you can see that they protrude through the bottom of the box about 1/4" or so.
WELL...........
Little did I realize, but these screws are TOUGH!
Would a side-cutter/dikes be able to cut off the tips of the screws.........NOPE
Would a hack saw cut through the screws...............................................NOPE
Could I fit a grinder underneath the box and grind them off....................NOPE
Could I remove the box so that I could get better access.......................NOPE
Could my new reciprocating saw cut through the screws.......................NOPE
:aggressive:
Here was my innovation to try and grind down the screws (a side grinder with a large chop-saw blade attached to it (safety guard removed)
DISCLAIMER....Do NOT try this at home :D
This had the reach to get to the screws, but as soon as I fired up the grinder, the blade was slightly off-balanced and the whole tool damn near shook out of my hand.
Back to the drawing board...
Went back to Lowes (for the 2nd time that day) and found a 90 degree attachment for a Dremel which looked like it could squeeze in the small area.
The next task was to add a strip of fiberglass at the bottom of the box to add some rigidity.
Here was my "first" attempt:
While I waited for the resin to set up, why not rip off the gas tank on my R1 and check the air filter... :shrug:
Turns out I'm still a fiberglassing Noob because it didn't work out at all. :(
I forgot to add some resin to the MDF before adding the cloth so I didn't get proper wetting and the fiberglass didn't adhere like I need it to.
Plus the fact that my SMD Sunflash didn't set up well because it just happened to be mostly overcast which is rare in Colorado.
Plus I couldn't get a good amount of direct sun to shine in the back seat area of my car...
I even tried holding up my plexi window from my sub-box and reflecting some sunlight into the rear-seat area......nope, didn't work either.
Sooooo I ended up ripping out the fiberglass attempt and need to try again, probly with a time based resin and not UV based.
I'll save the Sunflash for my trunk area where I can get better sunlight access.
Speaking of new tools...
I used a birthday gift card to get me an AC/DC clamp meter finally.
Should be handy to analyze some electrical currents around the car and make sure everything is working like I think it is.
Have a good building weekend and I hope that you guys are having better luck then I!
Cheers :drink40:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Ur ballsy.. doing that in an M3 trunk lol
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Yep, I was super hesitant at first. :o
As things progressed, I got a bit more brave.
I have no plans of getting rid of the car and besides, returning it to stock would be a nightmare even if I haven't done too many modifications.............yet. ;)
I'm sure the BMW purists would hate me, but I see no reason why the performance can't be included with some great audio as well.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
more pics of that sexy r1? lol you are amazing at what you do man
WTF? Hybrid parking? Really? What the hell is going on with these smug bastards?! I want gas guzzler parking right up front so i dont have to circle the parking lot 40 times and ruin the enviroment.
  • Who's Online   0 Members, 0 Anonymous, 1041 Guests (See full list)
