running my electrical.
I rest at 13.9v at idle. How much will big 3 help that?
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
and so i need 1/0 ring terminals. battery post extended, heatshrink? anything else im forgetting?
torch, silver solder and flux.
and fuse holder and fuses
Edited by Tarball
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
ok got it. and i cant solder i realised. they all work good buuutttt. they didnt hold... so they got heatshrinked and they worked
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
the soldering job didnt hold up, so you put heatshrink to hold it on? thats seriously not a good idea. either practice soldering more, or buy a 1/0 crimper
Did you use flux on your connections before you soldered?
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
i used flux but some did hold others didnt. they all are connected good tho if they didnt hold i used vise and semi crimped em. i dont think i had enough solder inside them is all. but heatshrink just help if they were loose
i know i might have to redo them just not right now
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Loose connections will cause quite a few problems, better to have it right the first time. Biggest thing is you can cause the connection to get ridiculously hot. Voltage drop, weak charging. Just to name a few more potential issues.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 1185 Guests (See full list)
