Get Louder
This is the first Layer of the upper box. This is considered a 6th order bandpass using the upper box as enclosure with the opening being the port....I am hoping between the two i should be around 55-60 htz.
The sides are mated on the outside, the top will have the second layer mated then screwed into place. Sandwiching the mat between the two layers. I have to be able to Remove the upper box top to remove subs if I have any issues...its a long process ( about two hrs)
This is the first time I am using the bass knobs to adjust speaker output voltage. The amps are just too hard to get to. So far it has worked out pretty well. I meter at about 1/4 then 1/2 then 3/4 volume. So far it looks like my peak is around 55 htz. When the second layer is done it should stiffin box and change the Freq a little.
Since you technically have a wall. If you want louder numbers, I would suggest building a larger enclosure from bottom to top, and have all 4 woofer firing forward and placed on the passenger side and have a forward port on the driver side.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
How those planet Audio 3k amps work out for you. Any problems with them? was thinking of getting 1.
i cant build a wall the subs are 18s and there is not enough room, unless I want to go with a sealed box (never)!!!! no room for the port. As for the amps I bought them remaned for 250 each. Blew one the first round of tuning. But since then I have been testing alot and the rest have been holding up.
you have a wall. you just dont realize it. Seal off around your enclosure.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
hell if you just cover up the area where the subs are you will have a 4th order :)
just use plexi over it so you can see it
  • Who's Online   1 Member, 0 Anonymous, 1810 Guests (See full list)
