Box design approval + Question about woofer placement
Thanks 412, back to your statement on shooting for 3.5 cubes net...I realize that I have low power, but that seems like a loooooot of volume. Manufacturer specs are ported box volume: 1.5-3.0 cubic feet, with an optimum volume of 2.25 cubes. I am unsure about this, as compared to your knowledge of box design and building.
Edit: poor choice of wording
Edited by Phawstir
2000 Jeep Cherokee
15" Alpine Type R box build coming soon!
This is based on using the recommended power to the sub as well. Since you are running low power to the sub running a larger enclosure will let the sub move more freely without restriction.
Edited by varietyguy
anything below 2.5 cubes for a 15 is ridiculous. shoot for at leeeast 3 cubes.
More box builds
I'm with captain stupid.
I also agree hence going a bit bigger with the box
When designing a box for slot port 14-16sq" per/ft is what you are after
Also with a slot port try to not go over 9:1 ratio the closer to 1:1 the more efficient,
The more efficient the smaller you can have a port hence aero a at 9-13 per ft
My self I like my ports in the high 14 but thats me
If I were you 2.5-3cuft
14-15sq" Per/ft of port
How is this lookin' then?
Edit:
Also, my woofer mounting depth is a sliver under 9 inches. if the ass end of the woofer is pointing towards the port wall (along the internal back side of the box), there will only be just over an inch of gap between the magnet and port wall. Is this acceptable?
Edited by Phawstir
2000 Jeep Cherokee
Do you listen to a lot of chopped and screwed music? personally i'd shrink the port area to around 14 per cube, and raise the tuning to 33-35 hz so you can still pick up some of the higher notes.
More box builds
No I don't. Ideally, I'd like this box to slam some lows, but still be musical for rock, metal, and other genres. Anything is going to be better than my 42hz tuned prefab in use at the moment. Thanks for the advice 412 you're really helping me out. I'll go see what numbers I can throw together. Any other advice would be much appreciated
2000 Jeep Cherokee
this is what you want. you're underpowering the sub, so a bigger box should give you the best output. usually a smaller port area will sound a punchier for your metal and rock,
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
unless I'm wrong, you forgot to change the port height AB18VFL. Thanks for your input, I'm trying to balance quite a bit and with this being my first ported build i want to make sure I'm taking steps in the right direction. I listen to pretty much everything. For sure a good chunk of dubstep and rap/hip hop, but i still would like some musical capability for other genres, though they get a slight bit less playing time in my Jeep
2000 Jeep Cherokee
wow youre right, i did forget to change the port height.
i listen to alot of dubstep and metal. yesterday i build a big box alot like the design i gave you, except for a 12. im very happy with it.
2005 Subaru Impreza
My build log.
  • Who's Online   0 Members, 0 Anonymous, 1865 Guests (See full list)
