I do compete with MECA and thats why I was trying to figure out the best way to "defeat" box rise. Thanks bkolfo4 for all of your help. I am in the processing of reconing to a D1 and plan onadding more amps in the future. The first thing I planned to do was build a new box but thanks for saving me some money and telling me that isnt the best option. I will let you guys know more once I get my sub reconed.
Some AWESOME inputs from a couple of loud guys with great knowledge, i do agree with them, i stopped worrying that much about impedance rise long time ago, i prefer efficiency just like skittles, bigger boxes don`t need that much power , my current box has something like x3 impedance rise and still does a 147 @ 41 hz using a 2K amplifier and 2 12`s :)
Also like BK said, if you are tuned to 40 hz and burping @ 45 hz you might be tuned to high for comps, but that depends on way too many factors, i can tell you this, NO MATTER WHAT THE BOX SIZE IS, my explorer gets louder tuned below 39 hz
I run a 26 cft box and I only have 2 times rise.You can also run larger speaker wire which can help.I currently run 4 guage to my subs and i have noticed a big difference .I have had big box rise in small enclosures and large enclosure.There are alot of factors that can effect box rise.
^What subs to u have in 26 cubs?
Same ones that need 4 ga speaker wire to bring down the impedance rise :)
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
proof of difference?
Hmmm. What voice coils, and what load on each amp?
If you are running 4 ga from the amp and jumping to multiple coils/subs, it could make a difference. That could be up to 90 amps through the speaker wire.
If you have each coil run back to the amp, no way. Even with 1 ohm coils all in parallel. 2000 watts at 1 ohm is only 45 amps. 8 ga would be more than enough, unless the amps are 20' from the subs.
Current system:
Previous systems:
It doesn't really apply to the original question, but with enough current, power is lost if the wire is undersized.
Wire has resistance, current flows and voltage drops. Voltage drop and current flow is power lost as heat in the wire. Heat increases, resistance increases, more power is lost.
4 ga would be overkill in most cases, but I can see wiring scenarios where 8000 watts would benefit.
Current system:
Previous systems:
  • Who's Online   0 Members, 0 Anonymous, 7793 Guests (See full list)
