What's up everybody? Ive got a 2003 Tahoe with two aq hdc3 18s walled behind the second row seat. Behind the box I am build a battery box and was planning to mount the amp on top. The amp is a brand new crescendo 3500. Question is, will it get too hot back there since there is no ventillation? It has room to breathe but nowhere for the hot air to go. And I'm not sure how warm these amps get. And there's really no where else for me to put the amp. Thanks!
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
get a few hoses and run it from your air con to the back but im sure it wont get that hot
:ninja:
Edited by vibrator
Henry Ford once received a letter from a depression-era bank robber responsible for the deaths of several law enforcement officers, killed in their attempt to stop him as he fled the crime scene. In his letter, he thanked Mr. Ford for making his Model A Ford such a good getaway car.
Lol idk if I trust myself tapping into my ac. I thought about fans but how would I power them?
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
Use the power from your batts and just run a switch, what ohm load are you running at 1 ohm it will be fine! They barely get warm
1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
the easiest way to power the fans that ive seen is simply tap into the amps remote
Edited by Junior Russell
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
the easiest way to power the fans that ive seen is simply tap into the amps remote to trigger a relay that the fans are powered by.
Fixed so he don't fry shit. But the fan won't do much if there is no cool air being supplied to the area. All the fan will do is blow the hot air around once the amp gets warm and the rear is closed up.
Just run some kinda flex hose from a rear AC vent and have it be dedicated to cooling the amp.
the amp will be running at one ohm. But I'd like to be sure it won't get too hot on 100 degree days. as far as the ac, at the time it doesn't work. going to recharge it asap. but that would mean taking out the whole headliner and running a tube to the back? I've never done any type of a/c work.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
true i didnt take into acount that it will be sealed up and idk never messed with relays to much and all the remote is doing (by my understanding) is providing a 12v reference signal telling the amp to turn on therefore the remote would still provide the refence signal but would also be providing the fan its 12v power
  • Who's Online   1 Member, 0 Anonymous, 122 Guests (See full list)
