sub directions? all up or sides ? box help!
i think up it will get you better numbers
. . . sides will get you better quality i think
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
To get the most out of it you could do 4 to the top and 4 to the rear and ports to the drivers side. Or something more interestinfg like ports thru the rear deck and 2 on each side of the box and 4 to the rear. Should be nasty either way you go.
NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! TEAMHIGHX-CURSIONsig-1.jpg
Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
how does this look !? 12"x26"x36" with 3/4s thick wood. = 5.13 interior volume. with port and sub displacement thats 4.03 cubes, if i measure the tuning with 2 20" 6" aero ports, im at 35hz but thats before displacement if i measure after all displacement im at 40hz... is it after or before ?
how does box look ?
depending on how you want to cal the displacement
but with your box dimension this would be smallest idd build it to, if you wanted slot you could have a lower tune, my opinion is 32/33flat suit this sub, but that my opinion
you have the cone area of close to 2x18 and the power of 3-4 of them, i some how dont thing 3/4 will cut it, Ive even be tempted to go 1.5"
but seen as its a temp box 1" should do
Please somebody PM me the link to this program.... ^^^^ thx
EDIT : I found it guys!
Edited by SPL KID
i have the cone area of 2 15s actually.. and bracing is key, though most likly will double the sub side.
and can you make me a 30-33 hz box using the 2 6" ? you can cut the 20" length if need me... also the width is 26" and depth 36"
Dude! Where you gonna put the aeros with 12" box height and 8 8's?
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
