copper nuts and bolts
LOL at people talking about which bolt has more resistance.
You are talking about 1 inch of metal, which has less resistance than your entire run of speaker wire to be honest.
It's not a big deal.
we're talking .0001 ohms of resistance.
you are for getting the ring terminal resistance then the loss of contact area washers and nuts then times that by 2 because your doing the same on the other side
you have to drill a hole for bolts why not just drill a bigger hole for speaker wire then fill it in with hot gule or caulk done....
the only time i have use the bolt method was for comps when i was switching ohm loads for daily vs comp.... for ease of use/switching ohms
Nicely said. so at the end of the day, it's .005 ohms :D
I understand the fact if you are competing but it isn't going to matter if you just want the thing to work.
We should bust out the DMM and do a test how much resistance there is on just that section.
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
.005 ohms? Have you tested this? I putting 80 plus amps and over a hundred volts through my 8g speaker wires.. I don't want mulyiple contants that my signal has to go through to reach subs..ease of changing ohm load is the only good reason to use bolts..as far as splicing into your direct leads either solder or use big blue wire nuts like I do...
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
and the resistance difference between crimping and soldering is even less than that, but people still fight over it :rolleyes:
I've done copper threaded rod, copper washers and copper bolts before. It worked fine for my purposes (at the time @800watts RMS). The issue I had was over time it developed corrosion. This was in my earlier days of audio, after the corrosion developed on the copper I eliminated the copper and tapped a hole through the wood for the 8ga and as mentioned above filled the gap with hot glue.
It's probably insignificant but I have always been concerned with the length of the wire when using the bolt method to be able to switch the wiring on the subs. the neg to pos run for the series load would be very long. I like to keep the circuit short as possible and symetrical.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
For those who direct lead through the box, do you caulk the whole afterwards?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Shweet, just wanted a confirmation on that. I would much rather do direct leads because as n8 said, i wont be switching ohm ratings.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Thats why I want to do it, ease of switching the ohm load, no luck finding solid copper bolts, went to 4 or 5 different places. I did get a tip though, 1/4" copper bolts for a toilet, haha, i'm going to go look, besides the 8ga copper ends have 1/4" anyways so it doesn't need to be any bigger
Every toilet I've ever installed i've used brass flange bolts, but I guess I never really looked for copper. Good luck!
I hate long signatures....
...what the fuck is wrong wiht you you fucking fuckity fuck fuck head...
Mtnbikecrazy55 Feedback
  • Who's Online   0 Members, 0 Anonymous, 1145 Guests (See full list)
