I'm putting together a list of equipment for my next build. I have everything pretty much down pat, but am lost in the world of RCA cables. In particular I'm looking at these Rockford premium ones, as well as a several different Knu models. Furthermore, I see Wicks using high-end coax with RCA ends on it in his M3, so that has me thinking as well.
My questions:
How much shielding is enough? I know some have just a basic mylar/foil layer, and others take it a few steps further.
Does the metal/plating of the connector matter in the least?
Thanks
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
Thanks for the plug! :)
Depends on a lot of factors.
Where you run your cables.
How much noise you have to contend with.
How much you want to spend.
Type of output signal your HU and amps can take.
A lot of companies use "twisted pair" as marketing hype but unless you have differential outputs on your HU and inputs on your amp, it won't do anything for noise.
Coax cable has an outside shield which helps eliminate radiated noise from the car.
Most general coax has pretty good shield coverage at like 75-80% or something.
The stuff I got was double shielded with like 99% coverage.
Overkill? Maybe, but if I was going to run it then it wanted to make it as good as possible rather then have to fix some alternator whine later.
As you can see most people probably run generic RCAs and have no issue. If so great, I just wanted to try something out of the box and see how it worked. My build is still in progress so I have yet to even hear those cables but we'll see.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Quality of rca's make a massive difference.
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
TaylorFade, on 02 Jul 2013 - 9:38 PM, said:
Go back to that place, ask to speak to that dude again, look him dead in the eye and then.... pop him in the snot box.
Tell him T-Fade sent you.
In my experience shielded RCA's add more noise than they block. I believe that the install of the RCA's will make a far more noticeable difference in sound quality as compared to using expensive cables.
I ran the ixos 1000 series rca's for a while they were alright. I switched to the 5000 series from them they were a major improvement. I heard things through them more clearer and detailed than I did the 1000 series. They were louder as well. Then I ran the stinger 6000 series. I couldn't really tell that much of difference. Then I ran the eks from KNU. I didnt think an RCA cable could be much better but I was wrong. They were a major upgrade from the 5000 series from ixos and 6000 from stinger. I know that RCA quality is an important part and does play a major role.
Lots of good info so far. There are just so many brands, and they of course all claim that this thing about them makes them the best...
My feedback thread
I also used RG-6 Coax to my sub on the last build. Now pretty much completely re-doing it all and will be using RG-6 quad shield throughout.
i think ill be buying the stinger 8000 series
thanks for leading me to this thread by the way ^_^
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
