I just got a DC level 5 18" sub. Right now its in a shotty box thats way too small and has a piece of 8" pvc pipe for the port that sticks out of the box about 6". Now it's loud as hell but I really want to build a new box with a slot port. Here's the dimensions I have to work with. 44" long x 24" tall x 12.5" deep. I want it tuned to around 32 to 35 hz. I have no idea how to figure out how big to make the port and how long to make it. I used the pinned calculator up top and came up with a 2" wide port thats 22.5" tall and 18" long. Here's a quick drawing using paint (please excuse my horrible paint skills lol).
and here's the results of the program I used. I know I didnt get it right. My front plate will be 2 pieces of 3/4" MDF for the sub to mount to.
2004 Nissan 350z slammed on topspeed coilovers
pioneer appradio
B2 audio Quota for sub
B2 audio HN15 sub
Lunar L2200 for highs
Infinity kappa 60.9 components in doors
Under construction still.
you are going to need a bit more space then what you have, unless you run a small, real small port,
you either need to wider taller or deeper
also with 12.5" that 11.75" and you sub is 10.5, that's not much room
1ST OR 2ND GEN S10?
You competing with it?
Musically and for decent numbers I always recommend flared ports. For this application I'd run 2 6" flared full lengths and corner load them and woofer firing up. You could do woofer forward and port up. In that configuration I'd use 4 4" flared ports. You'll move a lot of air and sound good but, lose numbers metering. I have lost count how many boxes I've built for my s10 but, my loudest single woofer set up was 1 18" woofer and ports firing up. It sucked for driving around but, it was loud.
right now its the same depth but not as tall or wide as my idea and its sub forward with port firing up. I don't like the round PVC ports. Can't I just do a square port like Steve uses? My problem is I have no idea what to build. And yes it can be bigger but I'm already uncomfortable with the depth its at now due to losing so much leg room. Someone feel free to show me idea's with hopefully a cut list and how exactly to do the port to get the tuning I need. Oh and its just a system for fun. But I may have it put on a Mic and its a 98 2nd gen
Edited by pssstgotbags94
pioneer appradio
B2 audio HN15 sub
Might be time for a blow though build bro. Gets your leg room back :-), I'm 6'3" I feel your pain on the leg room dude
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Not ready to go permanent like that. This is my first time with anything better than kicker lol. I'd like to just built a nicer box than this pos I'm using now and see what it does with 2 more cubes tuned better. Right now it has 3 cubes and tuned at 40 hz. The box is coming apart and rattles all to hell. It's loud as hell for me and is hard to breath when it's hitting.
pioneer appradio
B2 audio HN15 sub
Here's the current box
And my big 3 wiring
And here's the truck performing her main function
pioneer appradio
B2 audio HN15 sub
Any help? I'm buying wood tomorrow. I know what I need to build but have no idea about port. I'd like to do an up firing square port but need to know dimensions i need to cut to make it.
pioneer appradio
B2 audio HN15 sub
New suggestion hope that is suitable:
Enclosure Specifications:
Fb = 35.4 Hz
Vb = 6 ft^3
External Height = 25 in
External Width = 44 in
External Depth = 14.5 in
Port Width = 6 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 44 x 25
Left & Right Sides =
Side 1 = 23 1/2 x 12 1/4
Side 2 = 24 1/4 x 12 1/4
Top = 37 x 12 1/4
Bottom = 44 x 12 1/4
L Port Internal Assembly Parts:
Top to Bottom = 16 x 12 1/4
Edited by Joe X
That's exactly what I want except instead of gaining more cubes from going up ( I want to keep it flush with bottom of window) can you make it deeper? I'm willing to sacrifice more leg room. Can you do it like 14"-15" deep? However much you need to get the right air space. You can see how much I have between the current 12.5" depth and my console to work with.
pioneer appradio
B2 audio HN15 sub
  • Who's Online   0 Members, 0 Anonymous, 536 Guests (See full list)
