So my buddy an just got SSA Zcon 18" dual 2 ohm sub today and were trying to figure out the amp to get to power it. he already knows he wants crescendo but the question is do we match the subs rms rating with the BC2000.1 or do we go all out and get the bc3500.1 can the sub handle the 3800 watts or will we completely fry the sub.. were hoping we can get away with just setting the gain a little lower but what do you all think?? also do you guys have any advice for the best ported box design for that sub i cant fine any box specs. want it tuned to 30 hz maybe up to 33 hz but should we do slot port or multiple aero ports. and what shoud the net volume for the enclosure be? thanks for any help its all appreciated
Edited by jbiddle.com
Head Unit -- Alpine CDA-9887
Mids and highs -- 2 Crescendo PWX-8's
4 Crescendo PWX-6's
4 Crescendo FT-1 Super tweeters
Mids and Highs amps -- 2 Alpine V12 MRV-F545
Subs -- TBD
Sub amp -- Crescendo Bass Cleff BC2000.
Sub Box -- Ported box 9 cubic foot tuned to 37hz for 2 15 with 140 inch port area
Processor - Alpine imprint
Zcons are underrated in my opinion, but not half power under rated. Have fun popping that sub with the bc3500. Why not save up for a second zcon and then get the 3500 instead of trying to take short cuts and end up having just to re cone your first zcon and buy a second zcon so u don't over power it again.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
They have free box designs on their website. You can use the same box specs than the Xcon IIRC.
The BC 2000 is enough, but if your electrical is good enough for a 3500 w amp, go for it ! Turn your gain carefully. But this sub can handle much more power than rated, at least for burps.
If it's only for listening pleasure, your friend will love it with 2000 watts. Don't focus on watts, focus on an efficient box for this beast.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
A 5500 watts amp should be a great match with 2 Zcons.
The 3500 would be better for 2 Xcons.
The can take a ton of power, but they don't need it. I ran mine on 1500 for a while and it was loud.
Head unit: Pioneer P880prsFront stage: Alpine Type X 17PRO componentsComponent amp: PPI BK 800.4Subs: Two SSA XCON 12's in 4.5 cubes tuned to 34hzSub amp: PPI BK1300.1Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
Team SSA
Team Alerion
i have seen 2 dc 5ks on zcon 18s and they take a while to get warm. Yes they are underrated. The vehicle was steve mead's camaro.
Agreed multiple people are running 2x rated power. Unless your buddy has a solid electrical system stick to the bc2k.
Team SSA
Team Alerion
