BassBarbies Ford Edge Build Sundown,Shok, Project DB, Pioneer
Looks like i need to get to work
Don't Let the Pretty Face Fool You, I Roll Like a BOSS :D
2008 Ford Edge SEL
Pioneer Avh-4400 Head Unit
2 Sundown Z V.3 12"s
Mechman 270 Amp Alt Externally Regulated
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Lots of Stinger Road Kill Deadner
152.1 DB Legal TL Score (for now)
Build Log
http://www.stevemead...dge-sa8s-build/
maybe take 2 4 or 5" flares and heat them up to the point that they are flexible. then cut and bend the 2 flares to half circles then attach the 2 flares together. to keep it smooth you could use so bondo on the inside of the flare where the flares attached at and sand it smooth then paint it crackle pink? or what ever color you want.
the reason i said 5" flasre is because when cutting the flare so you can bend it to a half circle you might loose a some plastic so using 2 4" ports might end up smaller then 8" atleast with the 5" flares you could shorten them as needed.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Or you can ask him to build you flares that would fit your pvc pipe. Then all you have to do is gorilla tape the flares on and you can change it whenever you like.
precision ports are by far my favorite, you pay for what you get.
I tape them with duck tape and then I continue to tune and cut away to the size I like. After I find my tuning I fiber glass the ports then install them.
Hmmm...I like that,... especially on a build that needs to be tested and tested, changed, dicked with, and tested again to get what you want..............
And yes LIZZIE you need to DO WORK!!!!....
Thats a very good idea. Im going to build 4 different boxes this next weekend so when the subs arrive i can put them in and get to testing i need a 151 + before august 26
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
I know everyone has said subs up and port back, but in a few cases I have gotten better numbers out of the exact same box(airspace wise) with the subs back instead of up. Might be an option to try if it isnt already on your list.
Are you looking to just burp a 151?
I will try subs up port back, subs back port back, and subs forward port drivers side. and 151 burp would be ok
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
Well Ive been looking everywhere for a new alternator for my edge first i tried Dc Power, they said they will see if they can get one built for me in time but never heard back so i tried singer alts he said he can make one fore sure a 250 amp and 160 at idle. Mechman said they have a prototype being built right now and if tests good I will be able to get that one. Im sure a HO alt should help a ton.
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
Go with Mike. He is a stand up guy and his products are good. I loved my 350a units and am upgrading them to 400a units.
